Newbie Question How do I take the front panel and top off of my Maytag LAT2500AAE Washing Machine?
  • coopnow Jun 24, 2008
    Thank you.  That suggestion worked great.  I took the panel off to see where the machine was leaking from.  It is leaking at the base of the tub where the washer tub stem seal is.  I believe that this is probably too complicated for a lay person to attempt and that I need to call a repair person.  Is that your assessment too?
  • 413 Answers
Look carefully under the front panel. there is a clip on either underside of the front panel. Insert a putty knife or screw driver in the clips to release. Pull the panel upward until the top clips are released. This is one of the best machines Maytag ever made.
Posted on Jun 24, 2008
  • Richard
    Richard Jun 24, 2008
    This machine may be worth repairing but that will be up to you. The tub seal has failed and is not that hard to replace as long as the sleeve bearings come off easily...problem is, Maytag made sure that a lay person would not take their repair business away because every model of Maytag requires at least 2 expensive, special tools to disassemble the machine. If you spend the money to repair, it wouldn't be a bad idea to replace the bearing at the base of the transmission.
    Regards;
    reg501
    The FixYa Team!
Maytag Clothes Washer Top Loading LAT2500AAE - The tub leaks when it is full and filling and when draining.
check your water pump and hoses underneath. because if it's the tub actually leaking, you might as well look for a replacement
Oct 20, 2013 | Washing Machines
Lat2500aae We have a Maytag Performa, Model
it sounds like the shocks on the drum maybe failing. on this model the washing machine mother board is close to the outer drum. the out drum may have made contact with it. and not turning on the pump to let the water out.
Oct 06, 2013 | Washing Machines
I have a Maytag LAT2500AAE top load washer. The
check the balance ring on the tub just below the tub cover and tub cover gasket which can be done from the top of the machine by removing the top cover,while doing this pull and push tub from side to side and see if it moves easier in certain directions, if it does you may have a tub spring broken on the tub leading to an un balance condition cause the springs stabilize the tub like a shock absorber on an auto, if this is it then you need to access the lower unit area by removing the front cover of the unit there are screws at the toe kick panel to remove this panel
Dec 08, 2009 | Kenmore 24032\24036 Top Load Washer
How to get front panel off neptune fav6800aww washing machine
Just a quick search in this forum fot "Front Panel" returned this post which says it better then I could.
http://www.fixya.com/support/t538238-remove_front_panel
Jan 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
How do I change the washer belt on a Maytag Washer #LAT2500AAE
I figured out that the belt went on the bottom of the dryer. It was actually very easy to fix once I realized where the belt went. I made the mistake of opening the front cover of the washer first, which is why I did not see where to put the belt. Apparently, if the washer is not level (since I had too much for a load and it caused the washer to pull out from the wall), the belt shook itself loose.
Dec 03, 2008 | Maytag PAV2300 Top Load Washer
The drain hose on a Maytag model #LAT2500AAE is leaking so I would like to replace it. From the back panel, it is way inside and difficult to reach. How do I remove the front panel?
there are 2 clips at the bottom left and right that pushes in or you may have the one with 2 screws on bottom left and right cornier..
Jun 03, 2008 | Maytag Washing Machines
I have Maytag LAT2500AAE. I took off the front cover and I see water leaking from the tub bearing during the rinse cycle. I think I need the Tub Bearing Repair Kit PS60151. Is this a difficult...
Tub bearing replacement on ANY Maytag can be difficult. Even for experienced technicians, it can take 1 to 2 hours as long as there are no surprises (corrosion, stubborn bolt etc). Also, all Maytag washers require specialized tools for removing certain components of the machine.
May 29, 2008 | Washing Machines
Maytag LAT2500AAE- unbalanced
see if it has 4 adjustable feet on each corner on the bottom
get a bubble level from a hardware store and turn the feet to raise or lower OR you could use something else to raise the sides until it is leveled by looking at the bubble level.
hope this helps
thanks for your rating
Jan 09, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
209 people viewed this question
Top Washing Machines Experts
