SOURCE: Most times when i turn on my computer, the screen flashes.
it means your computer has caught the ati2dvag bug. This bug seems to affect ATI video cards.
The 2 most common “solutions” are:
SOURCE: Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
SOURCE: Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
SOURCE: It appears to come on...then it goes black. If you
The problem can be in the inverter board, look for open fuse, or worst will be bad lamp/lamps. You need to open it up and report back what you see so we can guide you furhter: see what bad lamps look like: http://s807.photobucket.com/home/budm/allalbums
SOURCE: power button flashes but screen is blank except
hi, probably the transistors on the main power board. if these go bad, the capacitors should be replaced as well. repair shops charge 40-70 dollar to repair. i have repaired in past and they last maybe 2 more years after. may want to get another monitor and throw your up for sale broken on ebay.
Setting the Clock
To set the time for the Radio with
CD (Base):
1. Press the H button until the hour
begins flashing on the display.
Press H a second time and the
minutes begin flashing on the
display.
2. To increase or decrease the
time, do one of the following
while the hours or minutes are
flashing:
. Turn the f knob.
. Press ¨ SEEK or © SEEK.
. Press\FWD orsREV.
3. Press the H button again until
the clock display stops flashing
to set the currently displayed
time, or wait five seconds until
the flashing stops and the
current time displayed is
automatically set.
http://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/2k12impala.pdf
