Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY KV-36HS500 AFTER REPLACEING THE TWO CHIPS ON THE D BOARD. THE SET LASTED 2 DAYS..BACK TO 7 BLINKS.ORDERED THE $200 BOARD FRON SONY, WHICH ALSO HAD IC 504 REPLACED, THE SET NOW TUNS ON BLOOMS BLUE THEN PINK AND SHUTS DOWN..SO MUCH FOR THE SHOTGUN ATTEMPT..ANY IDEALS ON WHAT TO CHECK NEXT???
  • Anonymous Jan 01, 2009
    need a power supply for sony wega kv-36hs500, searched internet, seems like they dont make this part any longer anybody had this this issue
    Genius:
  • Sony Master
  • 1,673 Answers
I have had a bad high voltage multiplier (built on to the flyback in most models) cause the effect you are describing. When this happens it is possible for other components to be damaged.
I have also had a defective CRT cause blooming, and the colours to be very far out.
Jerry G.
Posted on Oct 25, 2008
My KV-36HS500 doesn't turn on.
You will need 2 MCZ3001D or MCZ3001DBs and two 18 pin IC sockets. the chips are on the d-board inside the tv.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony TV not turning on!
u need to change the lamp...same thing happened to me then i bought a lamp on ebay for $75n replaced it n now it works fine
May 28, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
this is almost certainly a ht proplem chech ht transistor by removal then turn tv on it should if so replace transistor be carfull high voltage may be still present on capacitors
Mar 30, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
My KV-36HS500 won't turn on it sounds like it wants to,but no picture,and standby light flashes 7 times,pauses and flashes 7 times again
The 7 blinks indicate that the horizontal deflection has stopped. This can be because the horizontal output transistor has shorted (common) or other defecive parts. If you are familiar with working inside of sets where potentially dangerous high voltages exist and can solder, let me know and additional details and instructions will be provided.
Dan
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Standby mode and can't get tv to work
    This sounds like the set is in protective shutdown. A problem has been detected and the set shut down. Normally when this happens, the standby light will blink a code count. Can you count the blinks and post that number here? That will indicate the circuit in which the problem was detected. Also, please confirm that the model number of the set is: KV-36HS500 as the blink codes are different based upon model.
    Thanks,
    Dan
    Aug 19, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony KV Trinitron WEGA 36" TV won't turn on
    My 36 wega did the same thing last week it must be contagious. Blinks 7 times mostly but sometimes 6 if hit power switch again. The problem is the D-boards shorted Flyback high voltage transformer but the ones Sony is selling $130 do not hold up and seem to burn out in a few days, yes twice bitten. Finally they send me new D-board can't wait to see if this fixes it once and for all. The board costs around $200 but is worth it to get it running again.
    May 02, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    Sony KV-34HS510 blink codes
    I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
    6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
    Nov 29, 2007 | Sony FD Trinitron WEGA KV-34HS510 34" TV
    Sony FD Trinitron Wega
    The power supply board is failing. There are twi integrated circuits in the horizontal drive circuitry that have to be replaced. The original integrated circuits are the same type and you will see written on each..."MCZ3001D" and need to be replaced with Sony # 670581001 or the "D" board with those parts on it needs to be replaced. The cost of the entire board is high-about $375.
    Nov 14, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
    118 people viewed this question
    Top Sony Televison & Video Experts
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
