Question about JVC AV32F476 32" TV
Av-32f476 picture shrinkage
I was wathing TV when the picture got black trim on both sides and the picture seemed too big for the screen. The words were cut off by this black line. Then as I continued wathing the picture all of the sudden shrunk to about a 12 inch square and had concave side to it. While I played with the remote the television turned off and would not turn back on. I later unplugged it from the DVR box and back into the wall outlet, at which time the TV turned on with the picture still shrunk and distorted. I would like to know if there is a simple solution, I am a handy electrition with some electronics experience, or will it require serious repair.
thanks
    Scholar:
  • 186 Answers
I had a Crummy Westinghouse TV that had a problem like this. JVC's are typically better built then a Westinghouse. My first educated guess - sounds like it's a voltage issue, most likely on the high voltage. Probably a capacitor on the power supply side of the motherboard or the capacitor in the flyback transformer. Just and educated guess.
Posted on Jun 23, 2008
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Picture seems to big for TV.cant read bottom words on screen and words are cut off on side also. Cant see scrores on any sports or read peoples names on bottom of the screen
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Mar 12, 2011 | Vizio L37 Television
There's a big black box obscuring the screen
Check the menu settings - closed captioning(CC) is propably on -switch CC to Off.
Oct 14, 2009 | JVC AV-32230 32" TV
JVC AV-32F476 on timer green no picture no sound
Power supply failure, expect to pay $100-150. worth the investment JVC made some good tvs Julio milleniumtvsvc@gmail.com
Jul 22, 2009 | JVC AV-32F476 32 in. Television
Toshiba 36 inch TV (8 Years Old)
If the shrinkage is just the top & bottom then it is relatively easy/low cost fix. Most probably, a capacitor in the vertical section is nearing end of its life. This would be the biggest of the bunch and would be something like 47uF/50V.
If however, the shrinkage is on all four sides, then it is the master power supply that is at fault. Chances are the main B+ is getting low which cold be caused by the big filter capacitor or an erratic regulator. This is not a simple fix and would require the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 10, 2008 | Televison & Video
Black square
If the picture can be seen on the sides of the black square you need to go to the menu and find the text and turn it off
Usually in the closed caption section
Mar 12, 2008 | JVC AV-27230 27" TV
Blank box
Turn off the Closed Captioning feature. On channels that don't have closed captioning, you just get a blank box.
Jan 24, 2008 | JVC AV-32F476 32 in. Television
Jvc Av-48wp30
try unplugging for a few seconds the plug it back in
Jul 11, 2007 | JVC AV-48WP30 48" Rear Projection...
Distorted Picture Proportions
well i beleive ur tv still have a warranty since it is purchased less than a month ago according to you. i suggest that u use it and have it check with their technician. it seems that there is an internal problem with your tv, particularly the vertical circuits. did u try to hook up another tv? this symptom is caused by a poor vertical linearity wherein the image is compressed or stretched at the top or bottom of the raster
Jan 16, 2007 | JVC AV-32F476 32 in. Television
JVC AV32F476 32" TV Logo
248 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
