Question about HP LaserJet 1015 Printer
Wrinkled pages the printer keeps wrinkling the pages when printer a page and leave darkish resides on one side of the paper
  • 35 Answers
Check the fuser film it may be dirty or must be repalce.
Posted on Feb 16, 2010
Every page printed has a wrinkle pressed into the paper
Its or moisture issue or wrong pressure between fixing roller and press roller.
Jun 30, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
Paper printing with wrinkles on hp 4100 laser
Pressure roller is worn. But the whole fuser assembly could probably stand to be replaced.
Mar 28, 2009 | HP LaserJet 4100n Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper Wrinkle when Printing
Its time you need to change the Tension roller of the printer.
Dec 16, 2008 | Office Equipment & Supplies
Wrinkled paper
bom dia, minha al 800 travou com a queda de energia e aparece h 4 naum sei mais o que fazer alguem pode me ajudarv a desbloquear??obrigada
Nov 02, 2008 | Sharp AL 800 Copier
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
HP LaserJet 1015 Printer Logo
119 people viewed this question
Ben Johnson
