Question about HP Deskjet 6980 InkJet Photo Printer
Printer ink making a mess of pictures
The last option (services) in the Properties menu does not do anything (now)
  • 2 more comments
  • mrfred Jun 25, 2008
    Thanks for your assistance .... Here's further detail since trying your help.
    Perhaps I should point out that I use the printer through my D-Link DI-624 router (wired) .... whilst my Toshiba Laptop communicates to the router wirelessly.
    I do sometimes use a USB cable coupled directly between Printer and Computer .... I also used that to investigate what might happen.
    The "resetting" proceedure didn't work using either coupling method. The same thing happened, and it seems IMPORTANT to note that after doing "the test" .... the last Window locked up and had to be closed using the TaskBar Manager. I could click on other tabs and get a representation of the contents. I didn't follow those experiments at all. It seemed to be more important to get Windows back to a stable condition.
    Incidentally, I can still print a bad collection of miscoloured pictures.
    I have been looking (in some depth) at the folders (Start/All Programs) .... followed by the "Proper" Folders for further information .... this was as a result of reading my *printed* Reference Guide for the printer. That suggested that there was a "User Guide" .... but, that file did not exist!!.
    It is a pity that this editing area does not contain the facility to add screen capture detail .... that would explain things in a much simpler way. I use screen capture regularly. ((and have prepared some for this content))
    I have looked inside the "Program Files" of HP .... where I can see 165MB of detail which I don't really understand .... but, I am willing to look at any detail that you may suggest.
    Thanks again
    Kind Regards
    Fred Belfitt
  • mrfred Jun 26, 2008
    Pity I can't use the Print Screen Capture facility that was available in the first "email".
    I went for the HP 6980 download (very big at 251.63MB .... that was a surprise.)
    I had to download it 3 times. Trying to do something with it caused an unresponsive Window which had to be closed with Task Manager.
    Eventually (more by accident !!!), I got a small Window which suggested waiting until a preliminary condition was set up (??)
    A larger Window eventually "arrived", with options that didn't suggest anything about a new (or replacement) driver.
    I tried some of the "options" when I also had the opportunity to go back .... which I did.
    One of the options appeared to suggest a driver situation .... so I followed that one .... Accompanied by not clear instructions and no feed back to me.
    The last Window showed a 96% completion situation with a varing download speed (I think) of about 15KB/sec.
    There was no other response .... and that window just "vanished" after about 20 minutes.
    I waited another 30 minutes .... Then, I tried to use the printer to do something. It was capable of printing more BAD pictures.
    The services Window would open but trying to activate the services failed with the usual warning that the services were not available.
    However, that warning Window could be "checked out" and repeatedly "activated"
    That Window did not go "unresponsive" this time, .... and the printing program could be closed normally.
    Regards
    Fred Belfitt
    I am surprised that you can add a response BEFORE you can have possibly read my comments and realised the consequences of what I have said.
    Surprised,
    Fred Belfitt
  • mrfred Jun 28, 2008
    As I have explained above, I have been to that site and downloaded and "installed it" .... with the effect that I have described.
    I have since found the original installation CD, and I'm wondering what is the "proper way" to proceed using it.
    Should I uninstall the original setup .... or what.
    Should I be using "Device Manager" to remove and replace printer drivers ?
    Regards
    Fred Belfitt
    Guru:
  • 1,894 Answers
No need to do device manager.
uninstall the printer driver from the programs list
then install the new drivers again
Posted on Jun 28, 2008
  • dewan nafees ahmed Jun 28, 2008
    sorry. dint see roboteks comments. both were same.
    but as far as i can feel there is nothing that can be done unless your printer responds to the signals from the computer.
    so if you are not successful in making the printer respond you cant do anything by yourself. that can be due to some faulty circuits.
  • 1,512 Answers
Hi fred
Deinstall the existing software and drivers , and reinstall software from the CD before plugging in the printer, See how that goes.
  • Graeme Ross
    Graeme Ross Jun 28, 2008
    get that up and going, then update the driver with the latest version you have downloaded
  • 58 Answers
Hello first, you can take a look for updated drivers at
http://www.techspot.com/drivers/driver/file/information/7395/ ,but you should be sure that your printer is pluged correctly way . thank you for using fixya
Posted on Jun 26, 2008
    Genius:
  • 1,665 Answers
  • HP Master
  • 6,487 Answers
Did you install the HP driver or your printer is just using the windows driver for it??
Posted on Jun 23, 2008
  • 91 Answers
Make sure your printer is plug in correctly and is turned on before connecting it to your PC.
    Genius:
  • 3,422 Answers
HI,
Did you try reinstalling the drivers?
  • Priya darshan Jun 23, 2008
    Please uninstall your printer drivers and reinstall them again.Let me know the result.
My HP Officejet 6500 stopped printing in color and all cartridges are new. What has happened? It was printing in color last week and today it stopped.
Welcome to FixYa!
Check if the printer has been set to print in black and white only.
  • On the File menu in your software application, click Print.
  • Make sure the printer you want to use is selected.
  • Click the option that opens the printer Properties dialog box.
  • Depending on your software application, this option might be called Properties, Options, Printer Setup, Printer, or Preferences.
  • Click the Advanced tab and make sure that it is not in Print in Grayscale option.
  • Click OK, and then click Print or OK to begin printing.
Thank you for using Fixya, have a great day.
Jas247
Jul 15, 2011 | HP OfficeJet Pro K8600 - - color - ink-jet...
My Epson Stylus R300 will not print black
The problem is either with the black cartridge or with black printheads.
First test a new black cartridge, possibly original, to ensure it is not the cartridge.
Perform a print head cleaning procedure using the printer tools in Winsdows, do this a couple of times.
If it did not work you will need to replace the print head or to take the printer to a repair shop.
Sep 13, 2008 | Epson Stylus Photo R300 InkJet Printer
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
PRINTER IS NOT PRINTING COLOR COPIES ANYMORE. INK WELLS FILLED
please check in the printer properties if the print in greyscale option is turned on
Mar 30, 2010 | Brother MFC 210C All-In-One InkJet Printer
I replaced my ink cartriges and I'm still have a blurr and fade on documents that I print.
  1. Open your application program.
  2. Select Print from the File menu. A Print window appears.
  3. Make sure EPSON Stylus CX9400Fax Series is selected.
  4. Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
    A printer properties or preferences window appears.
  5. Select the type of document you're printing for the Quality Option setting.
  6. If you want to print borderless photos, click the Borderless checkbox.
  7. Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
  8. Click the Advanced button. The Basic settings change to the Advanced settings.
  9. Make sure the High Speed option is not selected in the Print Options section.
  10. Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
  11. Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
Jan 18, 2010 | Epson Stylus CX9400 Photo Printer
Can i print with epson dx 4000 using only black ink i have run out of magenta can i alter my printer just to use black
Yes in the properties menu or setup of your printer you can look out for one word grayscale just click on that and you can deffinetly take a print out of anything in black and white. When you press ctrl plus P you can directly go for properties or option just browse for few minutes you will deffinetly find your grayscale option just check it and take your printouts.
Jul 20, 2009 | Office Equipment & Supplies
My 8x10 photos have half a blue tint and half a yellow tint. I cleaned the heads and aligned the print cartridges and that didn't make a difference. Working with a HP2610. Thanks! Leslie
Step 1 - Check the ink levels
  1. Open the Printer Toolbox . There are two ways to do this:Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Step 2 - Check the printer settings
      1. In the program being used for printing, click File , and then click Print The Print window opens.Make sure the appropriate product is selected, and then click Preferences or Properties .The Preferences/Properties window opens.Click the Printing Shortcuts tab.
      2. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .Paper size : Make sure that this option matches the paper loaded in the product.To see additional options, click the Advanced tab, and then click Advanced Features .The Advanced Features window opens. Consider changing the following option:Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
      Step 3 - Run the clean print cartridges utility
      1. Press the Setup button.Use the arrow keys to select Tools and then press the OK button.Select Clean Print Cartridge and then press OK . The device prints a test page.Examine the test page. If the print quality of the page is good, stop here. If the print quality is bad, go on to the next step for further cleaning.Open the Printer Toolbox . There are two ways to do this:
        • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
        • If the HP Director method does not work, open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click on Printing Preferences . Click the Services tab, then the Service This Device icon.
      2. The Printer Toolbox opens. On the Device Services tab, click Clean the Print Cartridges , then follow the on-screen instructions. Up to three levels of cleaning are available. Discard or recycle the page that prints.
      Step 4 - Print a diagnostic page
      1. From the product control panel, press * and # simultaneously, and then release both buttons.
      2. Press 1 , 2 , and then 3 . The Service menu appears.
      3. Press the right arrow button (c01150415.jpg ) twice. The Special Reports menu opens.
      4. Press OK .
      5. Press the right arrow button (c01150415.jpg ) once. The Print Cartridge menu opens.
      6. Press OK . The diagnostic page prints.
Jun 23, 2009 | HP Photosmart 2610 All-In-One InkJet...
All of a sudden it printed very faded, a light blue color. I changed the black ink cart and it still does the same. I only have a folder on my desktop with the HP manuel, etc. help I can't get into a menu...
Is your ink old? Replace your ink cartridges if they are.
To access your printers menus, go into the Control Panel and click on Printers. Right click and chose Properties. On the General tab, click Printing Preferences. The click the Services tab. Here you can clean your print cartidges or calibrate your device, if necessary.
Jun 23, 2009 | HP OfficeJet D135 All-In-One InkJet...
Photosmart C6300 pictures are printing very wet and grainy. printer is also very loud - almost as though the parts were scraping and banging.
Sounds like you have the wrong paper setting in your print properties. I would use photo or high bright 24lb paper and set the paper type in your printer properties prior to executing the print job.
Regards,
Worldvet
Nov 12, 2008 | HP Office Equipment & Supplies
How do i run a leaning cycle on hp psc 1610 all in one printer?
go to printer properties in your pc.
for going to printer properties just give the printout from the file and on that page on the right upper corner u can see properties.
then click that properties.
in that printer properties there will be option.in that ---service option----or utility option-----or maintenence option----or printing preferences option----in any of the above option there is a option given clean the ink head just click that option and continue.
Nov 01, 2008 | HP PSC 1610v All-in-One Printer
HP Deskjet 6980 InkJet Photo Printer Logo
47 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
