Question about Coleman Mach 15 Air Conditioner
Coleman airconditioner I bought a coleman pop up trailer with a colemen 7000 a/c unit. I was working great but now it runs for appox. 5 min and gets cold but it keeps tripping the breaker- I changed all the fuses with no success. I will say that it has beed very hot outside when it was on. Any ideas?
    Novelist:
  • 161 Answers
Try testing the capacitor (there may be 2 ) If the start windings can't kick out it will blow the breaker.
Posted on Jul 04, 2008
I need owners manual for 1995 coleman popup camper.I is a colman seneca.I bought it used and there was no manual with it.
If your looking for Coleman owner manuals or brochures call Beckley's! We have the last copies of these brochures straight from the factory. Limited quantities available so call 800-598-4048!
Pop Up Owners Manuals
  1. 1974 - 2011 Coleman Folding Trailer Owners Manual
Nov 01, 2014 | Sport & Outdoor - Others
Split system AC has pungent brussel sprout odor
clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Apr 17, 2014 | Coleman Heating & Cooling
Runs fine but only runs for 5 min then shuts off for 5 min then back on, will not stay running.
COLEMAN R.V. AIR CONDITIONER SERVICE AND REPAIR QUESTIONS
COLEMAN R.V. PRODUCTS
GO TO rvcomfort.com
Click on RVP (RV PRODUCTS)
Click on type of AC, if you can’t find the information you want there,
then click on contact us on the Green Bar.
You can get Service Support or Email address and Phone numbers.
Jul 25, 2010 | Coleman Mach III Air Conditioner
Connection to difusser too short.
We used to buy a roll of 25ft, or so, at the dealer I worked for in the past, for just such an installation, of the vinyl that is connected between upper & lower units. Attach it to top as other piece is with band clamp, let it drop down through the hole, peel tape off, stick to lower and trim it off. Worked great. Dealer you bought unit from may have some. Other set-ups I've run into lately are ducting made out of 4 pieces cut to proper length 1" insulation & taped together at corners, and before that was just heavy cardboard, bent in proper shape like opening, then, vinyl taped to inside of cardboard. It all worked, but personally I'd prefer the vinyl, at proper length.
Aug 19, 2009 | Coleman Mach III Air Conditioner
Coleman tsr rooftop airconditioner
NEED A FREON RECHARGE AND MAY POSSIBLY HAVE A FREON LEAK
STEVE'S APPLIANCE
516-300-3249
Apr 05, 2009 | Coleman Mach 15 Air Conditioner
I NEED A REPLACEMENT FUELTANK FOR MY 413G COLEMEN STOVE
Visit www.coleman.com, click on usa at bottom, then "find parts" enter model # 413g in search box and all available items pop up. good luck.
Sep 05, 2008 | Kitchen Ranges
Coleman tsr mach 3 RV Air Conditioner
I don't think you need a new one just a good cleaning and service. The unit has a liquid high temperature line near the compressor with a fan blowing outside air across it this coil gets clogged over time with air-borne dirt and pollen and leaves and such and must be cleaned regularly or the unit will be unable to remove the heat from the coil and during the peak demand (3pm) the circuits that protect the compressor and the trailer wiring from being overloaded and burning or melting will trip. From what you have described it sounds like the RV is working as it should with a condenser coil that needs to be cleaned. GL and happy camping!
P.S. I've only serviced the occasional RV unit but in those cases I laid a piece of plywood on top of the Rv for work platform removed the retaining screws from the top cover and used a spray bottle with a good heavy foaming cleaner a shop-vac and a brush to get the job done.
Jun 11, 2008 | Heating & Cooling
the fan motor bearings need lub....the shaft has a tiny access hole to put some oil into. because the fan shaft is slowing down, it is putting more strain on the voltage current, and eventually the internal breaker shuts down the ac........plus your condenser is not getting enough air accross it, compressor heats up, and it too will shut the unit down......older units have to be oiled every year, and eventually it too will fail, and a new blower motor assembly is needed or replace the ac unit.....blower motor units are around $130....now you install it or pay to have it done at around another $150 labor,,,,,try yourself, if it fails then call the tech........let me know ..ray..yyzazz@ao.com
May 20, 2008 | Coleman Mach 15 Air Conditioner
Coleman Mach 15 Air Conditioner Logo
306 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
