Question about Norcent Technologies PT4231 42 in. HD-Ready Plasma Television
Norcent Problem I just bought Norcent pt4233 second hand. Basically, after watching it for about 2 hours, I get 5-6 vertical red lines. They are very sporadic, and it looks like red pixels are moving around forming lines. I'm sorry for long description, but this is the only wayfor me to describe what's happening. I usually turn it off for about 10 min and that I can watch it for another 2 hours. I can also increase the brightness and then lines kinda disspear. I saw some threads on other forums, and people say that Norcent uses LG parts, and that I can order part from some resellers and fix it myself. The problem is that I dont know what to buy! I would greatly appreciate if you'd advise me what to do. Thank you.
  • 13,433 Answers
I work in computers for the most part,
Please ask Slinteriors
http://www.fixya.com/users/slinteriors
Hes the TV guy to ask.
Please don't rate this solution, don't rate don't rate don't rate dont rate dont rate.
Thank you,
Ekse
Posted on Jun 24, 2008
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
https://answers.yahoo.com/question/index?qid...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ...
forums.androidcentral.com > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
No picture on Norcent LT-2790 bk
There are two possibilities for this fault. The first one is with it deflection yoke connection. If this connection have any loose contact at main board side, horizontal sweep pulses will be absent to deflection yoke. Check this plug in connection first. If it is OK, check and replace the CRT connection socket.
Jun 04, 2012 | Norcent Technologies2703 27" TV
Can I reset the second hand and the lower dial on the watch?
long answer with info given, but this is what will explain it all that small subdial at the 6 area is the second hand that runs at all times, large red hand is stop watch seconds,allso on the center pin is the minute hand for stopwatch 2 o,clock subdial is tenths of a second, for stop watch 10 o,clock subdial is hours for stop watch
Jul 09, 2010 | Tag Heuer cj1110.ba0576 Wristwatch
Skips time
If it is not a feature built in to the watch to save power when it needs winding, I would say it has a bad gear wheel inside.
I would go here, join, and ask in the Rolex Forum,
http://www.watchuseek.com
These guys are really knowledgeable.
Jun 15, 2010 | Rolex Daytona 116520 Wrist Watch
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Dec 30, 2009 | Invicta Watches
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Analogue hands don't correspode to digital clock
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
1. Activate Crystal
2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
3. Push and hold (at least five seconds) the center crown
4. Watch will beep and word (SYNCHRO) will appear in the display.
5. Use the top + button to line up the minute hand right on the 12.
6. Use the bottom – button to line up the hour hand right on the 12.
7. When finished, press crown and you will go back to time.
Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
NORCENT PT -4233
Norcent PT4233 no picture, black screen, but has sound. How to repair
The display (PDP - Plasma Display Panel) at the heart of this unit is a LG 42V7 model. There is a known bad solder "defect" on the YSUS board that causes this board to fall unexpectedly.
The bad news is that you have to replace all the primary boards on the display - ZSUS, YSUS and CTRL boards, as the failure can/often takes them all out.
The good news is that LG makes a repair kit for this panel. Its part number is 687VSNB03E and it contains the three boards LG6871QYH036D (Y SUSTAIN), LG6871QZH041B (Z SUSTAIN) and LG6871QCH053G (CTRL).
Hope this helps
Sep 04, 2008 | Norcent Technologies2703 27" TV
Eske told me to ask you!
Are the vertical lines across the entire Screen? If so it could be the control Board. If the lines only go part way from the top but not all the way to the bottom. Depending on where they are it could be the x boards. can you post a picture of your screen with the lines?
Jun 25, 2008 | Norcent Technologies PT4231 42 in....
Norcent Technologies PT4231 42 in. HD-Ready Plasma Television Logo
104 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
