Question about Toshiba Satellite A135-S4527 Notebook
Toshiba satellite laptop
The pc shut down each 25-45 minute
  • 96 Answers
You can check your power options properties. Choose never of the turn off monitor, turn off hard disk and system standby... On your Desktop, right click and point to properties and point to screen saver you can see the power tab. click it and you can see the power options properties window. If the settings set same as i given. The battery of your laptop must have a problem.
Posted on Jun 26, 2008
Toshiba Satellite Automatic shutdown on startup
Try F8 upon start-up and use safe mode to boot then try a doing a system restore, it may have installed an update automatically that conflicts somehow
Apr 23, 2010 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A100 Win XP O/S. SHUT DOWN Prob.
sorry to say but sounds like a cooling problem or the bored is bad :(
Dec 29, 2009 | Compaq Presario 1200XL104 Notebook
On full battery my powermanagement shut down in 3
your battery is not working properly.pls checked it.
Aug 25, 2009 | Computers & Internet
Will not log off or shut down properly
sounds to me like a spyware problem.... i recommend downloading a spyware scanner and scanning your computer for threats
May 28, 2009 | Toshiba Satellite P300D-ST3711 Notebook
Toshiba p205-s6347 notebook pc shuts down without warning
Your laptop is probably overheating due to an obstructed airflow path or a failed fan. Get some canned air and thoroughly blow out any dust and debris that may be blocking airflow. Sometimes the heatsink cooling fins get matted over with fibers and a lint ball will form in the fan-cage obstructing the fan rotation. If this happens it is often necessary to remove it with tweezers which may require some dissassembly of the notebook.
Mar 19, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
Toshiba Satellite A105 laptop keeps shutting off for no reason.
I think your fan might be broken....if the fan doesn't cool the pc,the processor or the chipset will automatically shut down the pc to prevent burning hardware.Or your hard drive might keep crashing.Oh yeah and abstract from this i don't recommend ever using mcaffe
Oct 25, 2008 | Toshiba Satellite A215-S7422 Notebook
Toshiba Satellite A135 laptop
Try disconnecting power adapter and removing battery for two minutes. If the laptop still does not boot then there is an hardware problem. You can try taking out and putting back ram modules, but my suggestion is to take the laptop at a repair shop, if you cannot fix it by removing battery.
Jul 29, 2008 | Toshiba Satellite A135 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
41 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
