Sony KV-34drc500 not working
Hello, I have a Sony KV-34drc500 and is not turning on. When I click the power button It makes de sound like something is starting. The red light blinks but i cant see anything in the monitor.
Can you help me?
    New Friend:
  • 76 Answers
From your statement i found that there is a problem in deflection section. And then you didnt mentioned about how many times the red light blinks. Number of blinks gives some information in which section the failure occurs. Please give correct information.
Posted on Jun 24, 2008
My Sony Wega Model KV XR29M31 won't turn on.
Visit the site named 'Electro-help' for more details. Click this link. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 900 posts to different brand TVs now.
Oct 06, 2012 | Sony WEGA KV-28HX15 28" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
You have a blown fuse. It should be a GMA7 amp or a 5 amp. You could try to replace it and see if your TV works again. If it blows the fuse again, then there is something shorted causing the fuse to blow. Then call a good TV Tech.
Aug 03, 2009 | Televison & Video
Sony KV-32XBR96S Wont power on,Just makes clicking sound
I have the same problem with the power button clicking on and off was there a solution? Is it worth fixing?
Nov 30, 2008 | Televison & Video
Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Oct 05, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony Trinitron KV-27EXR25
Just this week I had the same problem. If you are hearing a click responding to your pushing on the power button then it is more than likely a short that is preventing the problem. In my case it was a matter of dust.
I fixed the problem by opening up the back of the set and blowing all the dust out. There was a ton of dust accumulated on the circuit boards over the years. Once the dust was cleared I check to make sure the power fuse was not blown and it was fine. I then closed it up and it turned on without a problem.
My Sony is over fifteen years old and it still works like a charm. Its not HDTV, but it works great. When it finally goes; then I will buy a much bigger flat screen HDTV.
Good luck.
Jul 21, 2008 | D-Link DE 805TP (DE-805TP)5x10 Mbps...
TV turns on......eventually
check for a bad cap ,relay sound ok or could be a bad solder connection in the power supply at the regulators
Dec 13, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
