Question about GE JES1288SH Convection/Microwave Oven
Where is the light bulb located?
My microwave works just fine, but the inside light bulb is not working. I can not figure out where it is located to change it, or what kind of light blub I have to get to change it. Any help will be greatly appreciated. How to change the light bulb in the microwave
  • Bigdeel Jun 26, 2008
    Internal light is out, and don't know where or how to remove it to get a replacement. Also cooling fan has stopped working now, but unit still cooks. I've unplugged the unit for a coouple of minutes to see if fan would work again on power up, no change.
  • GE Master
  • 9,098 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://tinyurl.com/gv383
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there.
There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
TO BIGDEEL
Do you mean your internal cooling fan or the hood / vent / exhaust fan?
If it's ther internal cooling fan, do not use the microwave or the magnetron will overheat and be damaged or destroyed.
Posted on Jun 29, 2008
Microwave interferes with TV
Take one fluorescent light-bulb -- not connected to anything -- and a darkened room. Start the microwave, and see if any emissions from it activate any of the fluorescent materials inside the light-bulb.
Mar 15, 2014 | GE JVM1653 Microwave Oven
I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads and without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
I would say you have blown a fuse on the unit. As you now have found out, that's one of the reasons why you unplug any electrical equipment before working on them. You will have to take the outer cover off the microwave and locate where the fuse is. It is most likely on the back of the main PCB or possibly inside a plastic sleeve or mounting near where the cord enters the unit.
Feb 22, 2014 | GE JVM1440 Microwave Oven
Riccar microwave oven RM 700N Light no longer works - can't figure out how to get to the bulb to replace it.
1 Unplug the microwave oven from the outlet. Wait 20 minutes for the capacitor that is inside the microwave to discharge.
2 Unscrew all the screws around the casing by turning them counterclockwise.
3 Remove the cover by lifting off.
4 Locate the light bulb in the microwave. This will be located on either the right or left side.
5 Unscrew the light bulb by unscrewing counterclockwise. Some light bulbs are held into the socket by two notches; for these you will need to gently push on the bulb and turn counterclockwise to remove the bulb, then pull out of the socket.
6 Place your new bulb in the empty socket and secure by turning clockwise until tight, or if the bulb is one with notches on both sides, then guide the notches into the slot on the socket, push gently and turn clockwise until clicked into position.
7 Replace the cover and screw back on. You are now done and may plug back in the microwave.
May 02, 2011 | Microwave Ovens
Lights and fan quit working
there are fuses inside the microwave but there not the kind you would have in the house,,unless you can buy them it cant be fixed by you,
Jul 03, 2010 | Hotpoint RVM1635 Microwave Oven
GE MIcrowave model JVM1631BJ01 hood lights won't work
The part that controls that is goes through your control panel on your microwave. For the lights to come on to start with the door being closed switches have to be working right and when you press start the lights come one. When the microwave is through cooking and you open then close the door then the lights should go out. The logic IC on the control panel board that detects all these events is not being reset correctly. Unless you get a microwave tech to track down the component on the control panel circuit board it is not something that you could do on your own since it takes voltage and signal checks with the proper equipment and then some soldering and desoldering of the defective component(s). Good luck and God bless.
Dec 22, 2008 | GE JVM1631 Microwave Oven
Kenmore Microwave Model 721.67601790 lights don't work!
This is actually a common problem which we repair on a regular basis.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 19, 2008 | Microwave Ovens
Light bulb
If you are comfortable with taking the cover off, Unplug the microwave, usually there are 2 philips screws on the top back, 2 on the right back and 2 on the left back edge cover. Sometimes, their might be a screw on the bottom but you will notice this right away if there are or not if the cover doesnt come off.
Then located the light bulb. You should be able to see the opening from inside the microwave where the light bulb is located.
Once you locate the bulb, then there are usually 2 types, type 1 screws in and the other type is a bayonet type, which you push down, and then twist. You should be able to figure this out.
Sometimes there is a plastic cover that is placed around the bulb to kinda help focus the light towards the inside of the microwave.
Once the bulb is out, then take it to your local hardware store and see if they can match it up. You might want to call first to see if they carry them before driving all over the place.
Hope this helps.
Good luck.
If i have helped you with you question, then please remember to post a feedback and a rating.
Thanks.
Mac
Feb 19, 2008 | Westinghouse WST3504 Microwave Oven
Unscrew the vent at the top of the microwave(2 phillips head screws)
inside to the right you'll see another screw holding a metal panel. Unscrew this and take the panel off and you'll see the bulb, which will unscrew counter-clockwise
Nov 03, 2006 | LG LRMM1430 Microwave Oven
Fan and Lights do not work
Sorry a bad controller printed circuit board or what GE calls a smart board. I have seen these smart boards as low as 85 bucks, go up to a price of 179.00!
Sep 18, 2006 | GE JVM1651 Microwave Oven
GE JES1288SH Convection/Microwave Oven Logo
261 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
