Question about Tripp Lite Internet Office INTERNET550U (INTERNET550UINTERNET550U) UPS System
Keeps beeping Tripp lite keeps beeping - green lite is constant green, red (overload/check battery) is not on.
  • 1 more comment
  • what a trip Sep 17, 2008
    the tripp lite keeps beeping, green light on
  • catarino_uno Nov 04, 2008
    won't stop beeping; green light on, red light flashing
  • assistant821 Dec 09, 2008
    It's probably part of the myriad of electricity issues in the aftermath of Ike, but the Tripp Lite has been beeping periodically today. It doesn't usually. We did get notice from our management company to shut down all computers this Friday, since the electric company will be doing some work in our area. Could this be the problem?
3 Suggested Answers
  • 5 Answers
SOURCE: UPS Internetoff700 keeps wont stop Beeping
this is normal when especially when we have short flow of power,or power spikes,surges and sags.it is not overloaded at all i had such a problem some times back en ma technician told me it is ok
Posted on Feb 10, 2008
jvpacoin
  • 91 Answers
SOURCE: Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Posted on Jun 04, 2009
SOURCE: unable to open the enclosure, how, no screws visible?
There are 2 (very deep) screw holes at the back of the UPS, but you'll need a long (8"+) philips screwdriver to access them.
Posted on May 13, 2010
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound.
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
Tripp Lite OMNI 1000 LCD will not stay on
Feb 19, 2010 | Tripp Lite OMNIVS1000 UPS System
It's brand new, 4 beeps and a pause
check the user manual, but that battery will need to be charged for a period of time before it goes full load.
Dec 06, 2009 | Tripp Lite INTERNET550SER (S4863566) UPS...
Jun 03, 2009 | Tripp Lite Lite SmartOnLine SU2200RTXL2U...
I bought a TrippLite Internet Office UPS surge protector in January 2009. I have misplaced the manual. Recently it began to beep for no reason. There is no power failure. It was so annoying I had to unplug...
this unit come with 4 with battery backup of 12v 7ah. check what are the indicator display shown?
it very diffcult know what the problem if u can give more info. u can try to replace the battery with new batts.. and test the ups if it not beeping again it show the battery problem. or maybe you had plug in more the the power consumtion that why it keep sound the alarm indication overload try to serperate the load. if u wan a user manual go to this website to download the manual: http://es.tripplite.com/support/manuals/index.cfm
u will get will u wan...
Apr 12, 2009 | Tripp Lite Tripp-Lite Internet550U 550VA...
Feb 08, 2008 | Tripp Lite BC Personal BCPERS300...
Tripp Lite Internet Office INTERNET550U (INTERNET550UINTERNET550U) UPS System Logo
629 people viewed this question
Top Tripp Lite Computers & Internet Experts
Joseph Hoffmann
Brian Sullivan
Brian Sullivan
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
