Question about Acer Computers & Internet
DVI CABLE THE DVI CABLE CAME WITH MY ACER MONITOR AND LAPTOP. WRER DO I ATTACK TYHE DVI CABLE TO MY LAPTOP.
    Novelist:
  • 119 Answers
If you get to see a dvi port then attach it there. if there is no dvi port then look at the cable closely whether it is an adapter or watever
Posted on Jun 24, 2008
Acer monitor no signal
If your monitor has various input sources, make sure it's on the correct input source in the main/input menu. If that's not the problem double check the cable for bent pins also make sure if you have a video card with DUAL dvi outputs that your using the correct one.. as the other one might be secondary and non-functional. It's possible but highly unlikely if you unplugged the DVI cable while the monitored was still powered on it could have damaged the video card of the computer or mainboard of the LCD monitor. When in doubt try another DVI cable if all else fails.. if you have another DVI monitor (thats a known good) try that also to make sure that the video card is not the problem.
Nov 05, 2013 | Acer H243H Monitor
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Are acer monitors unable to pick up HD video inputs?
There are two types cable to connect to LCD Monitor. VGA and the other is DVI,ight need DVI cable it has flat pins and is larger than the VGA small round pin models.
Dec 21, 2009 | Acer X193W LCD Monitor
Trying to connect Acer X213W monitor to Acer 3613 laptop. First Q-My laptop does not support 1680 x 1050 resolution, can I still use the monitor?Second Q- I can't seem to locate where to connect (hardwire)...
1. Yes, the monitor will just display the resolution set by your laptop.
2. There should be a VGA port on your laptop, it's a trapezoid shape with 3 rows of 5 holes and usually blue. Since your monitor only has a DVI cable, you need to get a DVI to VGA adapter to be able to plug your monitor into this spot.
Dec 27, 2008 | Acer Aspire 3613WLMi Notebook
Computer won't recognize monitor driver
Its the usb, if u connect the monitor via the standard port, the vga port, it will work. If your monitor only have an dvi cable you can fix that by an adapter. That adapter should be an DVI to VGA.
Good luck to you
Dec 11, 2008 | Acer AL2016W 20" LCD Monitor
DVI connection to DVI port on PowerMac G4
DVI offers better picture quality since no DAC occurs.
But to most of us Analog VGA will do
Rifaa
Aug 02, 2008 | Acer X193W LCD Monitor
Acer AL2002W Monitor
For DVI you need to probably upgrade your cheap graphics card, something not that expensive would be a ATI Radeon HD2400 Pro, it'll do. May want to check what pwer supply maybe required on your PC.
Jan 20, 2008 | Acer AL2032WD 20" Flat Panel LCD Monitor
Connecting dvi cable straight to acer monitor
The cable box is probably outputting a resolution the monitor is not compatible with. Computer monitor and television resolutions are usually different, and not cross compatible in some cases.
For example, wide screen monitors are usually 16:10 aspect ratio, while TV is usually 16:9 aspect.
The AL2216wbd is a 1680x1050 display, while HD TV is either 720p (1280x720) or 1080i (1920x1080).
If your cable box is set to 1080i that would be too high for the monitor. You will need to set it to output at 720p, and even then you will probably get a vertically stretched picture since the monitor has a taller aspect.
Nov 15, 2007 | Acer AL2017 20" LCD Monitor
Computers & Internet Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
