Question about Packard Bell (160248-01) Computer Speakers
Speakers i have a packard bell computer screen with speakers which attach 2 side of screen, i need a new mother board for my packard bell hard drive stack so at the moment im usin a mesh computers PLC hard drive stack and ive plugged all the speaker cables in but i have been left with 1 cable which doesnt fit anywere, the cable has quite a big end compared 2 the other cables the number on the speaker cable wire is E148000, please could you help me with either were it goes or if i can actually use the speakers with a different hard drive stack thank u very much NA
    New Friend:
Packard Bell (160248-01) Computer Speakers with a 12 volt power source worked OK,
Tried a 9 volt and it also worked.
This pair of speakers is grey with a barrel design. The mounting surface placed flat is approximately 10.25 inches by 3.75 inches. Each end has a rainbow design with a depth of 2.75 inches. By placing with the mounting surface flat on your desk gives you an out of the floor design. The front edge from the desk to the bottom edge is 1.5 from the surface to the top edge with a 3.75 inch. Suggesting you may mount them under your desk, on the side by your legs or stand them on each side of your screen.
I am told they come in white and black also I found them rather large for what I need but your decision is you should be happy before buying a pair.
Posted on Jan 25, 2013
  • Jethro Gibbs Jan 25, 2013
    your screen.
This cable is likely to be the 12v power input. Packard Bell used to supply side speakers with 3 cables, two for audio signals and the 3rd on (light grey in colour) pluged into a 12v jack on the back of the rather unusal ATX powers supply.
Posted on Sep 21, 2008
SOURCE:
I want to reformat PB MS2303
Packard Bell is a computer manufacturer, now owned by Acer. Restoring your computer will erase the hard drive and install a fresh copy of Microsoft Windows. This is beneficial if the Packard Bell is showing its age and running extremely slow or has been hit with an incurable virus infection. Before attempting to restore the system, be sure to back up any data you wish to save.
1.Insert the Windows Setup CD/DVD into the computer's optical drive. The disc will have been included with the Packard Bell computer.
2.Restart the computer with the disc inserted. A black screen will appear when the disc is detected, displaying "Press any key to boot from CD or DVD..." Press any key on the keyboard to launch the Windows installer. The "Install Windows" screen will appear.
3.Click "Next."
4.Select "I accept the license terms" and click "Next."
5.Click "Custom" when asked what type of installation you'd like. The other option is "Upgrade," but in order to restore your Packard Bell system to its factory settings, you must reformat the hard drive.
6.Click "Drive Options" when asked where to install Windows. Select the C: drive and click "Erase." Select the unallocated space after it has been erased, and click "Format." Format the space using the "NTFS" file system.
7.Click "Next" and Windows will begin reinstalling on the Packard Bell's hard drive. The system will reboot when finished and launch into your newly restored Packard Bell.
Sep 09, 2011 | Packard Bell W3301 Notebook
I have a Packard Bell Imedia desktop not sure of the model. It was working fine until recently, I switched on my pc and after the boot screen "NTLDR is missing Alt Ctrl Del" message appeared....
Remove the hard disk and attach it to an USB hard drive adapter and then connect it into the USB port of a working computer. This computer will detect the hard drive as an external storage device, then you can open the various folders and files to copy your files to this computer or burn your data to a CD/DVD disc or USB flash drive.
Return you hard disk back to your Packard Bell so you can reinstall Windows.
Aug 10, 2011 | Packard Bell iMedia 6826 (P481000502) PC...
When I turn on my packard bell ixtreme 6052 nothing appears yet it does see computer but does not even go to bios and harddrive read light remains on and harddrive is constantly ticking like it's...
This could be lots of things (bad HD, bad Mother board, bad RAM,etc...) first you need to narrow down the possible cause, open the computer, take out every thing that can be unplugged (I MEAN EVERYTHING) RAM, PCI cards, VIDEO cards, all storages HD, CD ROM, etc... just leave the CPU and power supply plugged in, than power up the computer and listen for BEEP's if you hear a series of BEEP's this means the CPU, power supply and mother board are GOOD, than (with power OFF each time) re-install the components you taken out (ONE at a time) to see which device causes the system crash... I've seen a modem card causing a system mall function once rediculous but true...
Feb 20, 2011 | Packard Bell Computers & Internet
How do I connect the speakers to a packard bell computer
You need a Packard Bell motherboard for this. look on the side of the monitor in the slot, and you should see 2 dark patches (holes). poke the hooks of the speakers inside these holes then pull down. if they are correctly placed, they will not come out if you pull the speakers away from the monitor. Hope this helps! Max
Feb 10, 2011 | Packard Bell Computers & Internet
My computer stopped working some time ago, and I was pretty much certain my hard disk had died (SATA), so I bought a new Hard drive (SATA) and booted my computer....the bios didn't detect the hard drive,...
ONE BAD LEAD?
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive one bad lead will cause a computer to shut down
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 18, 2010 | Packard Bell Computers & Internet
Speakers not working - PS2 plug has come out
Honestly, if they are packard bell speakers they are 1. old, 2. may have a propritery connection that is no longer found. A new set of speakers will only cost $20 at walmart, might be easier to just invest in a new set!
Oct 04, 2009 | Packard Bell Speaker Computer Speakers
FITTING MOTHERBOARD
If you have not removed the old motherboard from the case, then you can identify the various front panel connectors as you disconnect them and label them. Some front panel connectors have labels printed on the connectors which makes it easy for you to identify its purpose. If you have already removed the old motherboard then you will need to trace each of the leads to the front panel to see what they are connected to (eg. the LEDs and switches etc).
You will also need to identify on the new motherboard the various connectors for each function, eg power LED, hard drive LED, reset switch, power on switch, internal speaker etc. If you are lucky It may be printed on the motherboard, if not you will need to refer to the manual.
NOTE the LEDs are polarity sensitive, if the LED does not light, then swap the connector around the other way.
Nov 16, 2008 | Packard Bell Computers & Internet
Part number: 316809100002-R02
Sorry, this site is just for advise. You should contact the manufacturer's site for service.
http://www.packardbell.com/
May 20, 2008 | Computers & Internet
Packard Bell (160248-01) Computer Speakers Logo
292 people viewed this question
Top Packard Bell Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Packard Bell Audio Player and Recorder Expert? Answer questions, earn points and help others
