Cell Phones Logo
Posted on Nov 26, 2010
My nokia c7 display glass has been broken. how much will it cost
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 10, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
425
Points
My c7 GLASSS IS BROKEN AND WATS I WILL DO HELP ME AND I WANT NEW GLAS
Hi i m facing the same prob. phone asking for unlock code. my IMEI no is 356252043938858
What's your network carrier name?
If you need an unlock code for your network locked phone visit Unlocking4U.com Here you can unlock your phone at low cost.
How unlocked lock code of nokia c7 my IMEI:353755049659982 i entered wrong lock code
How many times have you entered wrong code on your Nokia C7? Nokia phones has only limited attempts. Don't waste the attempts with wrong code. Better visit Unlock-Zone.Com to get the accurate unlock code for your Nokia C7 at affordable cost with easy unlocking guide. Good luck.
Jun 05, 2014 • Cell Phones
Sim card not valid
If your Nokia C7 phone displays an error message saying "Insert Sim (or) Sim card not valid" then your phone is probably network locked.
To unlock it,visit the site OnlineGSMunlock.com here they are providing the unlock code at reasonable cost with easy step by step unlocking instructions and unlock it.Then you can use freely any GSM network Sim card.
My new nokia c7 is crushed off recently by a car and its display is smashed off.... can it be repaired? if yes how much does it costs
In theory ..the display can be replaced and it is quite easy to do it ...The problem is if it still works or not...and do not have other things broken too ..If only the display is damaged...it can be replaced..Here is a link on ebay ..where I located some displays and prices..but you have to have in mind the handwork ...and this can not be estimated..cause it depends on the shop ..or the person which will do it.If you have the tools (special screwdrivers and being a little handy ..) you can do it yourself ..cause all you have to do is to open it ...locate the plug for the ribbon ...remove the old one and plug in the new one ..but there are steps and a few things that can be in the way ..and I recommend to either go to a shop ..or ask someone who knows what is doing ..
here is the link I mentioned.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=nokia+c7+display&_sacat=See-All-Categories
My nokia c7 was crushed off by a car and its display is smashed off. . .and the rear panel is badly crushed..... can it be repaired....if yes.... how much it costs..........
No it cannot be repaired.The only thing you need to do is to change it.You can contact mobile repairing shop to get it or to replace.Good luck
Nokia c7 is not displaying
you can contact the service provider........
My phone doesnt display the name of person calling even its saved! mobile c7 nokia
MAKE SURE THAT THE SAME NUMBER SHOULD NOT ASSIGN FOR 'TWO NAMES'..
Nokia c7-00 When switch on the phone, it displays : "Phone start-up failed Contact retailer."
Hi, it should be a hardware problem, and just bring it down to your nearest service provider or nokia customer care center and they would probably give you a replacement set.
I need unlock code for nokia c7 movistar spain locked
u can get the unlock code for your nokia c7 model from by using this link http://www.theunlockarena.com/
following instructions makes u easy to unlock your mobile
1 - Switch on your Nokia C7 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C7.
3 - Compose #pw+CODE+1#.
4 - The Nokia C7 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C7 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia C7
Each Nokia C7 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia C7 mobile phone using the form above.
Top Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Cell Phone Expert? Answer questions, earn points and help others
