Question about RCA OPAL M4001 MP3 Player
Stick on "please wait..."
Can't download anything... can't turn on to llisten. Says "please wait..." and that's all it does. Tried reseting it... didn't work. Tried plugging it in, charging it all the way and reseting it.. still doesn't work. Help!
  • 8,596 Answers
Make sure the lock is not engaged first.
I would go ahead and do the firmware upgrade for your exact model #:
http://support.rcaaudiovideo.com/downloads.aspx?product=187
If the PC won't recognize the device,
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Posted on Jun 25, 2008
Craig netbook CLP281 When we turn it on all it does is show the Android dude doing a spin on a blinking top. Tried the reset button on the bottom. Not sure what to do Please HELP. This is NEW and NEVER...
Ok there might be an issue with your firmware. Push the reset button and hold it for about 10 seconds. Make sure it is turned off. Then turn it back on and wait for a good 5 or 10 minutes, if the little android douche is still there then its stuck on a loop. I reccommend you install a custom rom that I found for mine:
http://dev-host.org/b1ufq9iixe9k/clp281_firmware2.2_HACK12_R4.zip
1) Download this, then unzip it and copy the wmt_controlscript and firmwareinstall (this one is a folder) on an SD Card which is empty.
2) Stick the SD card in
3) Wait for it to "upgrade" (it will take a while but you will be seeing the progress).
4) Remove the SD card reboot and you should be up and running!
Note: You need an actual SD card a USB stick wont work from what I have been told!
Feb 27, 2013 | Computers & Internet
My rca m6204 mp3 player is frozen and resetting it doesnt work
Extremely lucky i am,like a idiot i tried to format/delete all my songs on my M6204 RCA mp3 player then it was taking to long to load then i reset it with a tooth pick,then i tried to turn it on and the intializing screen said please wait,and was frozen their,i got extremely upset since it's my only music device i have i actually cried,anyway what i did is locked the screen then resetted it,while it was in reset mode,i plugged in the USB connector,and then i downloaded
Firmware Update/Restore Utility
the link to the site is here: http://www.rcaaudiovideo.com/downloads/?sku=TH1611
Hope this helps.
May 18, 2012 | RCA M6204 Video Mp3 Player With 2.0" Color...
The screen would only show the waves but not menu. Tried unplugging everything and restarting. No good. Tried holding start button down till it beeped and then it prompted to plug in contoller. AFter...
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 16, 2011 | Sony Playstation 3 (PS3) Console
I put a new Canon black ink cartridge in and it still says check blk ink and will not allow me to do anything further. I tried resetting. I tried turning it off and then back on and nothing. Any further...
Just..
1. Press and Hold down the Stop/Reset button and wait until the printer self restart.
2. Release the Stop/Reset button and wait until the printer fully initialize.
After that try printing again.
Please comeback and rate this answer.
Thanks.
Aug 18, 2010 | Canon PIXMA MX310 All-In-One Printer
My Acer Aspire One boots up but only runs for 5 seconds then click, and it goes blank. It has a charged battery and does this even when plugged in to the charger. I have tried to boot it up using F2 and...
hi there,
use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that’s important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn’t reboot by itself wait 5 minutes before turning it off, just to be safe that it isn’t still flashing the BIOS.
Jul 11, 2010 | Acer Aspire One PC Notebook
I tried to get computer back to factory settings and now i turn it on and the screen is black,it sounds like it is running though,and also the 2 lock buttons light up when turning it on..please help
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Feb 02, 2010 | Acer Aspire One PC Notebook
Freezes at welcome screen
Try to scan for viruses , if nothing happened , then try to update firmware !
good luck .
Jan 22, 2010 | Coby MP-C858 MP3 Player
My ACER Aspire One ran out of battery power so it was plugged in to recharge and left alone for a couple hours. When I returned to it and tried to turn it on...nothing. The green power light comes on and...
ASPIRE ONE BIOS FLASH RECOVERY
You can find the BIOS download here:
http://support.acer.com/drivers_download.aspx
Jan 17, 2010 | Acer Aspire One PC Notebook
Question is concerning Coby MP822-4G my screen turned but after downloading music, Attempted to reset that is when I got a blue screen that will not move
We bought a Coby MP3 player from Odd Lots and it just keeps saying please wait and never does anything else. We are idiots and lost the recepit and no longer have the package.....Help!!!
Sep 06, 2009 | Coby MP-C858 MP3 Player
Still Stuck on please wait...
The error message means that an update failed - did you try the AutoUpdater software from RCA's website:
Jun 26, 2008 | RCA OPAL M4001 MP3 Player
RCA OPAL M4001 MP3 Player Logo
21 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
