Question about Canon Office Equipment & Supplies
After my canon mf6530 is installed, the printer will not work. The error is omnipage error. Help!
Microsoft Vista was introduced after my priner was purchased. The drivers wouldn't work. I went online and downloaded the driver for the particular model printer I have and my printer worked perfectly.
Posted on Jun 26, 2008
Hello, We have the Canon Imageclass MF6530 in the office, and just gave and error reading: SYSTEM ERROR E100. Any help is greatly appreciated. Thank you for your time. Cheers
that is the laser cannot be detect.
if you can to do...
check all cable which connect to laser, perhaps there are just loosen.
but if it was look well. you must replace a new.
May 23, 2011 | Canon imageCLASS MF6530 Copier
I want to scan a paper and i want to save it as word so that i modify it. How can i do it?
It depends on if you have the full software installed. The MP160 documentation indicates it came wth ScanSoft OmniPage SE. Open MP Navigator and choose this program, you can output the scan as a text file. If you did a custom install, you may or may not have installed the program. If you omitted the program, do a new custom install.
OmniPage is an OCR program and will output to a number of formats (you will choose File, Save as) after scanning. Word can import RTF and most other choices as well as .doc files.
If you don't have the software disc, the software can be obtained from this URL:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=13368
Alternatively, there is a free OCR program (simpleOCR.com) that will do the same thing. However it doesn't handle text in columns (newspaper or magazines) very well.
I hope this helps.
Feb 18, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Cannot install omnipage se. wizard interupts process I cannot uninstall Omnipage SE. It interfere with my Internet Explorer also and I can't find anything that works to get rid of it.
Try this link - http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=13371#DownloadDetailAct
If helped rate fixya
May 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I scan an image from canon pixma mp150
Acquire Text The following instructions will give you the basic instructions to acquire text from a scanned document in Office Word 2007 using OmniPage SE.
  1. Ensure the Canon scanner driver and OmniPage SE are installed and that your scanner has been setup.
    Note: If OmniPage SE is not installed, the required Add-in for Office Word 2007 will not be installed
  2. Place the document(s) to scan on the platen or on the Automatic Document Feeder (ADF) (if applicable).
  3. Open Office Word 2007.
  4. From the ribbon menu, select the 'Add-Ins' tab.
  5. In the Add-Ins tab, click 'OmniPage' and then select 'Acquire Text Settings (OmniPage SE)'.
    The Options window will open.
  6. On the Direct OCR tab, click the 'Image Source' drop-down to select 'Scan'.
  7. Confirm 'Scan' is shown in Image Source section and then click 'OK'.
    The Options window will close and you'll return to Office Word 2007.
  8. Click 'OmniPage' and select 'Acquire Text (OmniPage SE)' to scan your document.
  9. After the document(s) is scanned, make corrections to the text items as appropriate.
I hope it helps!!!
Dec 01, 2008 | Canon imageCLASS MF7480 Laser Printer
How to scan using canon pixma mp150
I hoe it helps!!!
Mf6530 always says platen glass dirty but I've even cleaned both sides
Found the solution at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=239&modelid=13170&kbpage=yes , then enter "clean platen glass" in the search window, and select item #1 "ERROR LCD: PLATEN GLASS DIRTY, CLEAN PLATEN GLASS ". This gives step-by-step instructions on how to clean the area dealing with the platen glass.
Aug 20, 2008 | Canon imageCLASS MF6530 Monochrome Laser...
Printing envelopes
You will probably have to change your paper settings on the printer itself to proceed without an error. In the additional settings>Paper Size> change it from Ltr to Envelope.
Sep 17, 2007 | Canon imageCLASS MF6530 Monochrome Laser...
21 people viewed this question
old marine
old marine
