Question about Toshiba 55H70 55" Rear Projection Television
Parts for a Toshiba 55H70
I went on NESDA to get a repairman for my Toshiba 55H70 and he has had my tv for 3 months. The problem he believes is the Red Yoke and he claims that the manufacturere of the part is no longer in business and he cannot get one......should I go to someone else or is he speaking the truth
I had the same problem. Different model same chassis. 1 convergence IC overheating was caused by red yoke. NLA at Toshiba. Fortunate customer had an extended warranty and got a new tv.
Posted on Jun 27, 2008
I have a toshiba hd theare view tv. The other day
Hi
did you notice the standby light? or blinking lights? and how many blinks as you see?
Thanks!
Jul 08, 2009 | Toshiba 55H70 55" Rear Projection...
Tosibah 50hm66 not working
if he fied the tv and it cost that much he ripped you off...you can buy a brand new tv for 700.00 at walmart he overcharged you by about 500.00
Feb 01, 2009 | Toshiba 55H70 55" Rear Projection...
Light engine
where are you getting your parts from? sounds like someone may be selling you used parts to get more business.
Apr 15, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 55h70 Convergence IC
I used the SONY stk180's on my 55h70 and works great...2 years no problem.
Get the real thing though....the knockoffs do fail
I also made sure the contact surfaces between the IC's and the heatsinks were properly cleaned and used "Arctic Silver Thermal Paste" applied in an even thin coat on all contact surface areas.
Mar 20, 2008 | Toshiba 55H70 55" Rear Projection...
Toshiba HD projecttion TV, showing shadow images in red and green
I believe your talking about concergence ICs if so yes its an easy fix if you can solder.Let me know if you need more info.
Mar 19, 2008 | Toshiba 55H70 55" Rear Projection...
Flickers caves in on sides then shuts down
I can understand the frustration of the repair shop, as getting help from Toshiba is almost non existent. When the boards in any big screen gets hot and used, many components on the board degrade and in your case, it sounds as though the fix would be a replacement board. Unfortunately, you may not be able to get one. If your local repair shop can't find the problem you might ask them for the board number and do some research on your own for a board. Most wholesalers will sell to the consumer if you have a credit card, and if you can find the board, have your local shop install the new/refirb board and do whatever adjustments are necessary. Good luck. I hope this has helped in some way
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 18, 2008 | Toshiba 55H70 55" Rear Projection...
Toshba CF27E50/CF30E50/CF32E50
The convergence IC needed are STK 392-110 two of them and possibly a resistor or two If you don't know how to unsolder and solder I would suggest an honest repairman. most Parts distributors won't sell unless you have a business but you could try anyway. A volt-ohm meter is required "IF" a resistor needs to be checked or is burned. Convergence IC's are a common problem with all projection tv's. It may last another 5 years especially if you don't buy the generic ic's
Dec 30, 2007 | Toshiba 55H70 55" Rear Projection...
No picture
57H81 57 in. Rear Projection Television Go to above unit for tip on your problem.
Jun 22, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba Theaterview HD 52"
I have the same tv and had it fixed the problem is most likely the power supply a $50.00 part but I suggest you have a repairman do the fix. Total cost should be around $250.00 for labor and parts.Also unplug your tv for over 4 hours then plug it back in to see if it works they call this a hard reset.If this does not work after 4 hours try unplugging it overnight and then try it. That is what I did to use the tv until I got it fixed. The only thing it could be is the convergence circuitv if this is the case it should cost about $400.00
Dec 02, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 had convergence problem fixed that now vol.went out
check to make sure that the tv switch on the back panel for surround sound is not in the on position check the customer menu to make sure that the speakers are turned on
Sep 28, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 55H70 55" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
