Maytag washer mold is bad
  • M Linden Jun 23, 2008
    Your 2 for 2 with us and I'll try this ,Thanx sooooo much for such fast accurate answers A++++
  • artquote Aug 29, 2008
    i do leave the door open and the problem is there. last nite we stayed up cleaning mold and mildew from the detergent area and the rubber rim .... what are the health implications?
  • 868 Answers
On most front loads this is a common problem and is resolved by leaving your door open to allow the water to evaporate
Posted on Jun 23, 2008
What is the best way to clean the mold off the door gasket
I use to have the exact same washer. When Maytag was Maytag before the merger with Whirlpool they suggested using a mixture of bleach and Sunlight power dishwasher detergent. You can also usually find a washing maching cleaner like Tide washer cleaner or Washer Magic. Run it on the longest and hottest wash cycle. Stop the maching during the wash portion and wipe the door seal down well with a rag and ware gloves. Also make sure that the little drain hole in the center of the bottom of the door boot (gasket) is not not blocked up with lint or anything. If your mold problem is really bad you might have to call a repair man out to replace the gasket and clean inbetween your inner and outter tubs.
Feb 19, 2011 | Maytag Neptune MAH5500B Front Load Washer
Mold in washer door seal
Wash it with bleach, that will kill the mold dead. do it once a week when you wipe your washer down you will be in charge of the mold
Jan 11, 2010 | Maytag Neptune MAH6500A Front Load Washer
I have a Maytag Neptune 1st Generation and the washer door gasket always molds, how to clean and how to prevent molding
The Maytag MAH300AWW was the first generation front load washer. Your MAH5500BWW is a much newer version and has a boot drain and door venting to minimize the mold. Just be sure your drain (bottom center of the boot) is clear. Use a solution of 1/2 cup of Granular Dishwashing Detergant and 1 cup of Chlorine Bleach added directly into the tub. Run the machine through a hot was cycle (with NO clothes inside) every few months and this will reduce or eliminate the mold.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune Stacked Washer and Dryer, the front load washer door has mold on the seal really bad. The repairman replaced it once saying it was a recall. He said to leave the door open, which we...
Hi, Some of the best information that I have found has been on YouTube. Go there, and type in "smelly washer" or "moldy washer". There are a number of good tutorials there.
Best regards, --W/D--
Aug 01, 2009 | Maytag MAH2400A Front Load Washer
Black mold on washer door seal
this is a very common problem with the neptune washers.
use a javex and hot water solution and scrub the rubber boot.
you should also do an acid wash. (hot wash with bleach, and no clothes) if there is mold on the boot it is inside the washer as well.
There is a way to prevent this. when the washer is not in use, hang a small towl on the washer door, and do not close the door.
this will allow for air movement in the washer
May 27, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
83 people viewed this question
Top Washing Machines Experts
