Question about Liquid Video L17LCD2 17" Flat Panel LCD Monitor
Can't find another one
I have one of these monitors, and would really like to get another one just like it. The problem is that I can't find them! Do you know where I can purchase one?
  • Jorge May 11, 2010
    What is the Brand name and model??
    Thank You!!!!!!
Ebay and goodwill usly have them
Posted on Jul 14, 2008
Dark's too dark, Brights to bright?
Monitor Blank hanya dengan warna putih di monitor. bagaimana cara pengatasannya?
Oct 04, 2013 | Sceptre Computers & Internet
I have A Compaq monitor,edited
omg an antique monitor
a relic CRT monitor?????really?
is it really MV320????or a typo.
MV500s are CRT (heavy cathode RAY TUBES)
you model is rare now, no photos of it by you.so...
if not a CRT pig.
then it must be a flat screen monitor
the first ones, up to year 2010 used crapppy
CCFL back lamp tubes that are bad now. all are.
(unless never used)
call CCFL fail these ways.
dim.
white now yellow
dead.
blinks, or is intermittent,or strobes.l
the backlamps CCLF tubes are dead. all do that, or just die .
crt monitors
are junk and a fire hazard, trash it.
CRT fails more ways
sure dim,sure dead.
but it has 3 guns , RGB , red green blue.
the red gun loves to go weak first , red phosphors
are weak (a physics deal)
one trick (long long ago is to up the red gun levels, to compensate.
or lower Green/blue guns.
gun means "electron gun" deep inside the CRT neck
The CRT has even more bad effects, failed.
a huge endless list , if you want.we have it.
with photos
Jan 23, 2018 | Compaq MV 520 Monitor
Samsung dispaly .it showing two red colar lines on the moniter.it s like vertical lines. tell me the soultions
If there are vertical lines that do not change color then it sounds like dead pixels on the monitor. There is not really a way to repair it, nor is it really cost effective if it was, considering parts/labor will exceed the cost of purchasing a new monitor. Your best bet is to check if you have a warranty on the monitor and get it serviced. Otherwise, you'll just have to either put up with it or purchase a new monitor to replace it.
May 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I get the message Auto Adjust when i open the computer
This is a normal thing if you have it enabled in the monitors setup. Like your computer there is a little cpu in the monitor and this does checks and makes adjustments. You can setup the monitor to more closely match your video card but unless the message really drives you crazy seeing it all the time it's not really worth doing.
The Benq 17's have great displays. I'm using one as I type this.
Oct 28, 2010 | BenQ FP71G 17" LCD Monitor
On my HP2709m desktop monitor I am getting a pinkish screen. More so when I scroll down then the text turns really pink. This is a new monitor that came bundled with my computer from Sam's Club.
Try a different "data" cable between your computer and your monitor.
Try a different monitor on your computer, to see if the problem is within your computer's video-card.
Try your monitor on a different desktop/laptop, to see if the problem "follows" the monitor.
If the monitor really is "new", it is "defective" -- take it back, and get it repaired/replaced.
Jul 12, 2010 | Computers & Internet
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
Monitor isn't working
just replacing the fuse should help. There are two of them on the inverter board. depending on which one is blown will give you 2 different issues. One will cause the screen to flash content perfectly for two seconds and then drop out. the other will be really dark if can see any picture at all,
Feb 10, 2008 | ViewSonic VX900 19" LCD Monitor
Monitor is blank but green light is on
if you disconnect the data cable while the monitor is on, you should get a red and cyan message telling you to check the cable, that assures you that the problem does not coming from the monitor, instead check th video card.
Jan 23, 2008 | HP Pavilion M70 17" CRT Monitor
The color of the screen is not correctly appearing.
if your monitor has color controls try them,if your monitor has auto adjust try that too.if you can test the monitor on another computer try that as well to verify the monitor is causing the problem.if none of this works its safe to assume that the color control circuitry in the monitor has failed and with todays monitor prices it is cheaper to replace than to repair.
Dec 26, 2007 | Chi Mei Corporation 221D-NBC Monitor
Monitor flickers!!
I have also same problem with LG Monitor 700E, LB(in). I want circuit diagram/systematics of this monitor in PDF or any other format. Thanks in advance.
Dec 01, 2007 | LG Studioworks 700S 17" CRT Monitor
Liquid Video L17LCD2 17" Flat Panel LCD Monitor Logo
78 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
