You may have to remove and clean out your drain filter located inside the cabinet between the bottome of the drum and the pump motor. Make sure you hand bail the water out of your drum prior to removing the drain filter. Your model may have a shut-off valve between the drain filter and the tub, if so turn it to the OFF position to stop the water flow. If you do have this shut-off valve you will not have to hand bail the water out of your tub. After you remove, clean and reinstall the drain filter, be sure to turn the valve back to the ON position.
Hi
This issue usually occurs due to kinked drain pipe, clogged
drain filter or drain pump. First make sure that the drain is not clogged and
remove clogs if present. If no visible lint is present then remove the lower
front access panel to check the drain filter and drain pump for any clogs,
you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this
helps... Please post back for any further assistance.
Daniel
