Question about Dometic NDR 1292 Refrigerator
Not getting cool enough
My refrigerator suddenly stopped cooling effectively. It is a built-in unit in my RV. I live in a very hot climate and when I take the cover off of the rear from the outside of the RV it seems like the air around the coils is very hot. I tried running it on AC and propane to no avail. The freezer is still cold enough near the cooling element to freeze ice but everything else is defrosted. The fridge is so warm all my milk and eggs and such have spoiled. What should I do?
  • bigunted Jul 17, 2008
    Same here. I have to cool down the box w/ $10 worth of dry ice but it only gets down to 45 doing that
  • 4 Answers
Try moveing the thormister up in the refer it is on the right hand side of refer inside refer box if this does not help use a fan and blow it tru outside vent on low
Posted on Oct 17, 2008
I have a Dometic RM2652RBX Refer. The last two trips out it has given us problems. The first trip it worked fine all the way to Texas. We spent 2 weeks in Texas with no problems. We went to the Grand...
If the RV was level when it did not function. First you will want to open the rear vent of the fridge on the RV and check for a yellow residue above the burner area. If you do see that, then you will require a replacement cooling unit because the pipe ruptured. It is common in all new RV fridges that the cooling units lets go within 3 to 7 years. Check out ArctiCold Refrigeration We keep it cold the replacement cooling unit can be purchased through Ebay Dometic RM2652 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 17, 2013 | Dometic RM2652 Refrigerator
Haier model HRQ04WNAWW refrigerator. Stopped cooling suddenly. Compressor is hot, really hot, and doesn't make a sound. Light is still on inside of unit, so are getting power.
the compressor has an internal overlod inside of it after 115 degress it opens and wont start till it cools down below 115 unplug and try putting ice cubes on top of com pessor to cool it down otherwise it will take hours to cool off
Aug 07, 2011 | Haier HRQ04WNAWW 4.2 Cu. Ft. Refrigerator
Wiil not cool
If the heater is geting hot and not cooling sounds like it is in the defrost mode just defrosting or stuck in defrost mode.If it is in defrost mode it should stop defrosting after a while and start cooling. They defrost every so many hours depending on how they are set.
Jul 16, 2010 | Dometic RM2852 Refrigerator
Thetford N90 EL.L built-in has stopped cooling/freezing. It has power (the light is on) Any repair suggestions?
If it won't cool on all 3 power sources the cooling unit is probably faulty. Contact Thetford asap if the unit is uner 3 years old as it should be under warranty. Thetford won't sell a replacement cooling unit, their only answer is that you need to buy a new fridge at over £600. I have this problem too and am looking for another solution but to luck so far
Mar 28, 2010 | Thetford RV Refrigerator - N300 Model -...
Motor still runs after cool air stops coming out
See if helping the fan turn will get it going thrn let it run awhile.. The fan motors rake a set if not used often enough.
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
Quits cooling on hot humid days
The evaporator coil is not getting cold enough to draw the humidity out. You may need to clean the indoor and outdoor coils thoroughly. If the unit still isn't cooling right, it is probably due to a refrigerant leak in the system. You will have to to have the unit looked at by a professional if there is a leak. Leaks can be very difficult to find and very costly. Most of the time, it is more cost effective to replace it if necessary.
Mar 31, 2009 | Dometic Rooftop RV Air Conditioner
My refrigerator suddenly stop cooling and freezer camera is OFF
your refrigerator has a refrigerant leak, thats why you are not getting the cooling effect
Feb 20, 2009 | Refrigerators
this sounds like a compressor problem. if the outside coils are getting hot (and properly ventilated) but the inside of the unit is not getting cold then the heat is coming from the compressor.
Jun 28, 2008 | Dometic NDR 1292 Refrigerator
Dometic NDR 1292 Refrigerator Logo
284 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
