Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Vertical Grey Lines- WD 52327
Watched tv for an hour, turned it off... one hour later (for Eurocup) turned it on and there were vertical (a dozen or more) lines... cable worked, could see the screen behind... even when I turned the tv off, they stayed on for another 15sec. Other tv's in the house work fine, no lines, no problem with cable.
  • 927 Answers
Good Day, sara926;
Suspect the Light Engine part # 939P977010. This is an expensive item. So, I would suggest that that contact the manufacture and asked them if could give a concession for this; part and labor. They may not give labor but most times they will give you the part.
Good Luck, Big Irish.
Posted on Jul 10, 2008
What is the cause tv turns on about half hour turns off red flash
most likely the lamp. pt# 915P020010
Recommend Phillips, OSRAM, or Mitsubishi original, as others may not work at all or have a very short life.
https://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-52327
Mar 17, 2015 | Mitsubishi WD-52327 52" Rear Projection...
Vertical lines on tv
Your video driver or power supple board are going out.
Nov 17, 2013 | Mitsubishi WD-60737 60 in. HDTV
Vertical lines
hi there.. try this link they talk more about this problem and there is a picture lets see if your problem is similar to the one on web
your image is like this one?
http://www.fixyourdlp.com/forum/viewtopic.php?f=10&t=1283&p=4322&hilit=Vertical+lines#p4322
Mar 05, 2010 | Mitsubishi WD-52327 52" Rear Projection...
I have the WD-52327 52in rear projection and the problem I'm having is that. Frequently now when I turn the tv on there are several lines going vertically down the length of the screen. It'll remain on til...
It could be the Optical Engine. It is a expensive repair. I would call Mitsubishi to see if they would be able to assist you in getting it evaluated to confirm exactly what is causing the problem. You can reach the Customer Service line at 1800-332-2119.
Hope this helps,
Skyassoc
Jul 07, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Green or blue vertical lines on my WD52525
it is not the lamp. the DM board is causing this problem. if the DM is going bad the FMT is not far behind. it will cost you $250.00 plus shipping one way. see www.tv-techs.com
Jan 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Troubleshooting Mitsubishi WD-62327 62 in. Rear Projection HDTV
There are filters that need to be cleaned first off. Then I checked with some people in the TV Repair Business & they gave me for FREE some helpful hints before pursueing expensive repairs.
Nov 30, 2008 | Mitsubishi WD-62327 62" Rear Projection...
Green vertical lines
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Vertical flickering color lines instead of pictures
Take your set to a qualified tech you have a bad vertical ic or some cap around the vertical section is not filtering the voltage properly and your deflection yoke could also be bad.good luck.
Mar 16, 2007 | Sony PFM-42X1 Plasma TV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
