Question about Kyocera Mita KM-3035 All-In-One Laser Printer
Dark bands on bottom of all printed pages from rollers?
We changed toner cartridge and now grey 3/4" bands appear on all printed documents - what to do? Tks, Gary
  • Tim Babcock
    Tim Babcock May 11, 2010
    It could be the drum not cleaning proper or ther are scratches. Can you tell what that condition of the drum looks like?
    New Friend:
  • 48 Answers
When you changed the toner did you clean the printer? There should have been instructions that detail cleaning the charging wire and charging grid.
If you already threw those out please let me know and I can assist you with the cleaning. If the cleaning does not help than it could be a drum issue and I would recommend calling your servicing dealership.
Henry
Posted on Aug 15, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
Samsung printer printing grey
The exit mirror of the laser-scanner unit is dirty. There is a gap above the toner cartrigdge, where the laser beam is comming from. Try to clean with dry soft lint-free cloth.
Apr 08, 2012 | Samsung SCX-4300 All-In-One Laser Printer
XC820. All copies have a 3/8" wide dark band
There are a few different issues that it could be, the feed rollers could be dirty, as well as the belts into the fuser. Be really careful when opening copiers. Toner is really small particles of plastic that melt with low heat. Use a Hepa filter vacuum cleaner so you don't create a large mess. I suggest rubber gloves, q-tips and put down drop cloths or newspapers to protect the area around the copier. be really careful, most of the belts are mylar and are easy to break. Remember that toner is heat sensitive, brushing can cause it to melt. just try vacuuming first. if you get any on your hands, use cold water and mild soap.
Mar 03, 2011 | Xerox Office Equipment & Supplies
I changed the black toner cartidge for the first time and immediately got a multicolored stripe all the way across from top to bottom on the middle of the right side of the page. I replaced the toner
Vertical streaks or bands appear on the page.
One or more print cartridges might be low or defective. If you are using non-HP print cartridges, no messages appear on the device control panel or in the HP Toolbox. Replace any low print cartridges
Marks repeatedly appear at even intervals on the unprinted side of the page.
Internal parts might have toner on them. The problem typically corrects itself after a few more pages. The paper path might need cleaning. Clean the device. The fuser might be damaged or dirty. Clean using instructions in HP Toolbox.
Contact HP Customer Care.
Read this HP document:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00316826
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 25, 2009 | Office Equipment & Supplies
Why are documents printing with a black stripe on right side?
You most likely have a defective cartridge. It is also possible that your Charge and/or Transfer rollers have become defective.
Inspect the cartridge for any band of remaining toner.
You should notice one or two long thin rollers, with the cartridge removed. There will be a dark roller that should appear textured, but not dull. And they may also be a lighter colored roller with no marks.
These are the three common problems that create lines.
Lastly
If the band is mostly straight, it is most likely the cartridge
If the band is wavy or broken in anyway, it is probably the roller(s)
Let us know what you find
Apr 15, 2009 | Dell 3000cn Color Laser Printer
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Printing
check your toner/drum cartridge. lift the flap, do not touch roller (usually green), is the same grey band on the roller, if so replace cartridge.
May 06, 2008 | HP LaserJet 3050 All-In-One Printer
Grey band on left side of printed page.
replace toner drum or replace cartridge
Mar 19, 2008 | HP LaserJet 4 plus Printer
Kyocera Mita KM-3035 All-In-One Laser Printer Logo
245 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Adorjani Laszlo
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
