Dvd my sony dvd drive stopped working after installing vista
  • Anonymous Dec 03, 2008
    Same problem, works fine in XP, but then i install Vista and it doesnt work
  • franklinfcha Mar 22, 2009
    My DVD drive is too slow after installing vista..
    Most times even a full DVD is showing as empty..
    Get me a solution whether the fault is with the driver or the OS..
    If its with the driver get me the solution to solve it....
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 65 Answers
Hii legprev...
i think it is not d problem coming after vista installation...
see dere is sm problem inside urs dvd drive...
becaz by installin vista or ny other software wontmake driv not to worke........
thanks...
Posted on Jun 24, 2008
I have a sony laptop. The dvd drive only works sometime.I want to disable it and use one with my USB any help appreciated. James
You can go into the device manager (right click on my computer/manage/device manager)
Uninstall the dvd drive, when it tries to re install the drive stop it and you should be able to tick a box telling it not to ask to install this device again.
You can always remove the drive, this is usually just 1 or 2 screws under the base and pull it out
Jul 11, 2010 | Sony VAIO Notebook
Installing Vista on new hard drive- CD/DVD Driver not found
Are you installing from the SONY-supplied "System Restore" CD/DVD disks, or from a "generic" Vista DVD-ROM?
The SONY disks _should_ have the correct drivers for your notebook computer.
Dec 08, 2009 | Sony VAIO VGN-NR220E/S Notebook PC
Windows vista updated and now my optiarc dvd rw drive won't work
You will have to uninstall the drive and reinstall again. I think the drivers for the drive is not properly installed. But if all this does not work, then I think you will have to do a system restore.
Best wishes
Oct 29, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
Boot Disc's Not reading, Dvd rom help? or Xp/vista help?
How did you made it boot to the disc? if you used keystrokes to do so, it would be better if you go into your BIOS and set the boot priority making the dvd drive as priority and see if it is gonna work that way. If it does'nt you need to be concerned about the drive itself, it might be having problems as well.
Jun 02, 2009 | Sony VAIO VGN-S480B PC Notebook
CD/DVD Drive doesnt show
Right-click on the exe. file and see were run as administrator is click on it and then try to run the exe file again
May 31, 2009 | Sony VGN-CR320E/P Notebook
Vista ultimate does not pick up dvd rom
how did you use it? where you using your dvd rom when you were still in vista basic then upgraded it to vista ultimate? if so, probably you havent installed the drivers for your dvd rom after upgrading to ultimate.
Feb 06, 2009 | Sony Optiarc AD-7170S Burner
How to Install Sony DRU-710A DVD-RW
Cd/dvd drives don't actually require a driver to run. They use "class filter drivers" which are supplied by a burning program like Nero or NTI. These "class filter drivers" only add functionality to the drive. Windows just uses a generic driver "MSCDEX" to run them.
A couple of things to try:
Uninstall the drive. Open Device Manager, click on the + sign next to CD/DVD ROM drives, right click on the drive and select uninstall. Exit and restart your system. When windows loads, it will recognise a hardware change, and will ask if you want to install. Before you click anything, insert the disc that came with the drive (if you have one). This should then install, if not, let windows search. If windows can't find anything, select "I will choose the driver manually" and look for your drive in the list.
Another thing to do, is download the most current Chipset drivers for your motherboard (which I would recommend anyway, even if the above worked).
Update the Firmware version and the internal drivers for your drive. These can be found here: http://sony.storagesupport.com/product/112#drivers
Also, update windows to the latest Service Pack (SP3 for XP and SP1 for Vista) if you haven't got them already.
If you have Vista, did you recently update to SP1 via Windows Update? If the answer is yes, please let me know.
Hope these solve your problem
Regards,
Tim
Dec 09, 2008 | Sony DRU-710A DVD±RW Dual Layer...
Sony DRU-500A Won't read DVDs... at all.
INSTALL VISTA ANY WAY the problem is that windows can use the drive..
BOOT OF THE VISTA DISC
enter setup when the system boots up
go to booting options
and select the dvd rom as the first boot device
ensure the vista disc is in the drive
and save and exir setup
it will tell you to pree any key to boot from cd/dvd
and it will install vista without any hassle
Dec 21, 2007 | Sony DRU 500A DVD±RW Burner
Computers & Internet Logo
David Payne
David Payne
