Rank: Wiz
Rating: 79%, 59 votes
You should have no problem, if they are maxuum af. The others should work too- I have an Alpha 100. The alpha 100 works great. I used to run my own photography business, and searched around for quite a while before I found the alpha. There is an adapter ring that i bought, that makes it possible for me to use my favorite old pentax screw mount 135mm f1.6, or any other screw mount, on my alpha 100.
The only drawback I found was you cannot use any other flash(at this time) than the onboard one-or the sony only flashes-which are a little pricey. Different size hot shoe is the reason. I haven't found an adapter yet-but I'm sure someone will make one. The alpha doen't have a real time display- or asa of 3200. I'm hopeing for a firmware update/upgrade to correct this. BUT the newer models with a higher than a100 number do have realtime lcd, and do go to asa3200. And they use either sony mem.stick or CF cards happy shooting
