Get code 18771 0n toast 9 - Computers & Internet
  • 3,940 Answers
Here is what I found, apparently Toast 9 wants a MEG2 source file
http://forums.support.roxio.com/index.php?showtopic=36424&pid=194049&mode=threaded&start=0#entry194049
Posted on Jun 23, 2008
Washer wont drain or spin
I don't have a code book on this washer but sometimes they list some codes in owners manual. I think the code is drain problem..u will have to take the panel off locate the pump there should be a cleanout that might be clogged. the other day I found two kids socks in a clean out and it stoped it from draining. that is where I would look first, I hope this helps
Apr 08, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code ox8002006D on my mac dvd burner?
This is an error code for the DVD burner. The first step is to try burning at a slower speed, maybe even down as far as 1x. If that does not work, try reinstalling the driver or using a different burning application, such as Toast 10 or Toast Titanium. If those solutions do not work, you may have to get a new drive.
Dec 03, 2010 | Apple iMac G5 Desktop
2006 Saab Aero 93 won't start, battery is good, starter, alternator all good. will start if jumped
Get the battery and charging system tested. Sounds like the battery does not have any cranking amps. If you have a digital meter check cranking voltage. If it drops below 11 volts when you crank the battery is toast..
May 09, 2010 | 2008 Saab 9-3
HP dvd640e not recognizing DVD+R DL
6/25/9:  While this external HP DVD640e burner was listed as a NEW drive - "new" meant never used. A check with HP techs told me the unit was a 2005 factory closeout and the dual layer disc required for it is a 2.4 speed disc. I bought a 2.4 speed DL disc and it works perfect in it.  As far as seeing a CD when a DVD was installed is presumed also the fault of having the wrong speed disc in it (that lot of Memorex DL discs I am also having trouble with elsewhere too). Double-checking my profiler, it does give speed as 2.4x as the burner's profile. Alas, the problem was my newness to the DVD technology. A slap to the forehead and move on.
Jun 19, 2009 | HP dvd640e DVD±RW Dual Layer Burner
Toast 9 wont burn a disk
Do you have a Disk Burner? What type of disk are you trying to burn?
RCF
Jun 07, 2008 | Computers & Internet
Gpx download
Use Windows Media Player 9 or 10 only - don't use 11, or your mp3 player will soon become toast
May 12, 2008 | GPX MW3837 MP3 Player
TDK CD-RW Burner Sense Key Error
You may try this dvd creator for mac, I always use it to burn music and dvd, it works pretty well for me
http://macdvdcreator.mac-dvd.com
Mar 28, 2008 | Computers & Internet
Top element not heating
I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
If you attempt this repair, UNPLUG THE OVEN FIRST!
There is also a security screw at the bottom of the side cover.
Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
Error code on screen is E602-0003
i have problem in my cannon ir 3320 it shows
E602-001 & E0315-000d
pl solve it
Aug 22, 2007 | Canon (6981A002AA) for imagerunner 2200,...
Computers & Internet Logo
224 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
