Question about HTC S620 Smartphone
My tmobile dash lcd screen.
Hello, i bought a tmobile dash, and it was a little fuzzy sometimes and it had horizontal lines across the screen every once in a while, then i dropped it, had the lcd replaced, and now when i turn it on its completely fuzzy and then it switches to a white screen with a few horizontal lines. i really really need help please
  • 4 more comments
  • Anonymous Jul 21, 2008
    me too
  • klcummings09 Jul 31, 2008
    I woke up this morning and about 2/3 of my phone was covered in white lines. I dont know what happened, it wasnt dropped the night before or anything and it definitely does not have any water damage.
  • zachhupp Nov 28, 2008
    LCD screen completly destroyed
  • littleone91 Dec 26, 2008
    I turned on my phone and these horizontal lines showed up across the screen near the top. Will the lines spread throughout the entire screen? Should I get a new phone?
  • scm23h Mar 24, 2009
    White hirizontal lines on top 2/3 of screen
  • Anonymous Apr 19, 2009
    i think i leened againts something and when i turned my phone on this crack on my phone showed up any way i could FIX! it
Im trying it now i will post again if it works thanks
Posted on Sep 29, 2008
  • jason3694 Sep 29, 2008
    NOPE EVEN IN THE SETUP IT DOES NOT WORK!!! thanks for helping me delete all my important data
Lllkkkkkkkkklk;lkl;k;l;l;l
Posted on Oct 11, 2008
  • 44 Answers
Do this .... format & re-install the software... it works.
Posted on Jun 23, 2008
LG 42LB4D Pixelated lines across screen
It sounds that the digital video processor section has some malfunction. The set need through check up. Working with digital circuits, need sound knoledge in digital electronics, and expereince to do the work.
May 12, 2012 | LG 42LB4D 42 in. LCD HDTV
White horizental lines across the LCD Monitor.
This is a high voltage horizontal output problem. Could just be a loose connection or an intermitant component failure. If you can get into it, check for any loose connections. Sometimes this can also be caused by a large accumulation of dust. Make sure you unplug it before opening it up.
Apr 04, 2012 | HP LP2465 24" LCD Monitor
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
3 horizontal lines across screen and triple shadow on left side
its a LCD connectors. re-connect it properly. some loose connection.
May 25, 2009 | Samsung LN-T4071F 40 in. LCD HDTV
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
Horizontal line across middle of screen. screen flickers from that line down. what do i do?
Anytime you get lines on the screen that means the lcd is bad and needs to be replaced. As far as the flickering problem is concerned that can be a problem with the lcd and that would go away as well once you replace the screen or it could be the inverter which supplies voltage to the lcd and its a little board that is underneath the lcd.
Apr 09, 2009 | Toshiba Satellite L305D-S5895 Notebook
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Horizontal 'pinstripe' lines on all channels
sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Jan 16, 2007 | Daewoo DTQ-20N3FC 20" TV
HTC S620 Smartphone Logo
1,216 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
