Question about Garmin GPS
Garmin streetpilot c330 is frozen. pressing reset does not help. can you help thank you. bob
  • 10 more comments
  • hobo9 Jun 24, 2008
    what is a hard reset
    4 screws must be removed in order to remove the battery and it is also soldered in is my understanding. if i do this the warranty will be void
    reset button is very basic, first thing i tred did not work
    more suggestions please
    i think i forgot to metion that there is a raster screen showing words garmin upper left, and streetpilot in the center
    manual has nothing on removing the battery.else where it shows to remove four screws in front then unsolder the battery. to open up the case will void warrenty
    i tried that but the computer with drivers installed does not reconize it
    i have tried that also. thanks
    i believe this will void the warrenty
    anymore suggestions out there
    thank you
    i have tried all things suggested except removal of battery anymore suggestions please.
    thank you
    bob
    the computer does not see it also dose this help any
    Master:
  • 788 Answers
If it's still under warraty then I would contact Garmin about a replacement/repair if I were you.
Also, instead of removing the battery you could just let the battery drain by leaving it on.
Posted on Jun 24, 2008
    Master:
  • 638 Answers
Disconnect n reconnect the device to the poer source also try removing the battery n reinserting.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 44 Answers
  • kiran j Jun 24, 2008
    if nothing works.... format & reinstall the software...
    Genius:
  • 2,028 Answers
I've read a few forums about the same problem. If there's a fix no one has found it. If you're still under warranty, get it replaced. One forum read that the owner had sent it in to be fixed and even though it wasn't under warranty any longer they sent a new one.
    Genius:
  • 1,142 Answers
Remove the screws and remove the batteries and leave it turned of for 10 mins then reconnect it bac which should take care of the problem you are facing, all the best
Regards
    Genius:
  • 1,036 Answers
If none of the above solutions work for you, you could let the unit exhaust the battery, and then recharge it before attempting the hard reset mentioned earlier.
If the unit is still under warranty, it may be worthwhile returning it if all else fails. You will have to pay (recorded)delivery, but It would be better than voiding warranty by repair at this stage.
Their information is Here.
  • 796 Answers
Your device needs the firmware to be updated...
    Genius:
  • 1,665 Answers
Remove battery for a couple of minutes to reset it.
see user guide at link below
http://www8.garmin.com/manuals/StreetPilotc330_QuickReferenceGuide.pdf
    Genius:
  • 3,422 Answers
HI,
Pull the front faceplate off. There is a small indentation under the word Garmin which you could use a finger nail to lift off the faceplate. After the faceplate is off, on the right side is a reset button. Hold it down for 3 seconds and then try powering up the unit. If the battery is completely dead you might have to recharge the battery for about 10-15 minutes to get it to start.
If you need anymore help let me know.
Please don't forget to rate the solution
Goodluck.
  • Garmin Master
  • 13,433 Answers
Have you tryed pressing the reset button? What else have you tryed so far?
    Sergeant:
  • 260 Answers
If pressing reset does not help then you need to disconnect the device from the power source. remove any battery or hard wire connections for at least 60 seconds. then try again.
Ken
  • Ken Jones
    Ken Jones Jun 24, 2008
    If the battery requires you to remove the four screws then you are supposed to return the device for warranty work or replace it if it is out of warranty. The battery for this device is not designed to be removed by the consumer.
  • Ken Jones
    Another option is to keep trying to run the battery down until it is all the way gone. Then plug it back in. Eleminating all the juice from the battery will take time but is the same as a hard reset.
    Guru:
  • 1,894 Answers
Then do a hard reset and try.
it may help u
else get back to us
  • 3 more comments
  • dewan nafees ahmed Jun 24, 2008
    unplugged it during firmware upgrade?? because it can also cause problems like this
    Resetting Your c330
    If your unit locks up, press the Power button to
    turn off the unit, then press again to turn the unit back on. If this
    does not help, reset your C330.
    1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
    2. Gently pull off the face plate.
    3. Press the Reset button.
    4. Turn the unit back on; it will operate normally
    its ok
    do a hard reset:
    1. Hold reset button pressed for approx 15 sec
    2. Press power button while pressing reset button
    3. Release reset button while still pressing power button
    4. Device should start, hold power button pressed until you see white text on screen, last line should read "RTC..."
    5. Release power button
    normally hard reset means removing whole battery power from the batteries and then reusing them.
    its wil clear all memory errors in the processors.
    if nothing works
    Go to Garmin's website and update the firmware.
    http://www8.garmin.com/products/webupdat...
    This will solve your problem.
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
    if none of the techniques help, then try this way
    Try turning the unit off, then turn in on while pressing your finger on
    the bottom right of the screen and holding it there for about 30
    seconds. This should bring up the calibration screen, which will have
    you press dots to calibrate the touch screen. See if this helps.
    CREDITS:kevin A
    but if u r not even able to calibrate then screen has fault i think.
    actually the screen is composed of two parts, the actual lcd and a digitizer
    screen. There is a problem with the digitizer screen. If the unit is
    still under warranty get a RMA from Garmin and return the unit. If the
    unit is out of warranty then sell it and buy a new unit. It cost about
    $130.00 + shipping for the screen and digitizer and refurbished C330
    unit can be purchased on the internet with 2008 maps for about $140 +
    shipping.
    have u read all my comments??
My Garmin does not connect to sateliyes
Try Raising the antenna and then press the reset button when the C330 is on,this should restore the garmin, then: Make sure the C330 is fully charged and
I would try updating the C330 by connecting to to a usb port on your computer and then downloading Garmin Communicator. If that does not help then try contacting Garmin. I will attach a link to Garmin customer support. thanks for using FixYa
http://www.garmin.com/garmin/cms/site/us/support/supportcontact
May 05, 2011 | Garmin StreetPilot C330 GPS Receiver
Tip
How  OTRdriver's solution worked for me to clear up my StreetPilot C330 when it...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 09, 2008 | Garmin StreetPilot C330 GPS Receiver
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
My Street Pilot C330 will not navigate pass the where to/view map screen Screen seems to be frozen
I have a c340 and instructions say: if your unit locks up. press the power button to turn off the unit, then press again to turn unit back on. If this does not help, reset by the following: place your thumb nail in the groove located under the Garmin logo on the face plate, gently pull off the face plate, press the reset button, turn the unit back on and it should operate normally
Dec 27, 2008 | Garmin StreetPilot C330 GPS Receiver
My Garmin streetpilot c330
peel off the plastic part that says Garmin that surrounds the screen.. there is a button there that says reset.. press it... though.. you may lose some data.. not sure.
Oct 22, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 gps
reset button under thin band on face plate. mine did the same thing
Jun 25, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330
You will need to reset the device.
1. On the silver faceplat, under the word "Garmin", there is a tab. Remove the silver-ish fram carefully by pulling on the tab with your nail then by the sides.
2. once removed, press the reset button.
3. Once reset, the unit should work properly.
May 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c330 GPS
Hello, I have had 7 Garmin units and 4 of them where streetpilots like yours.
You can try a reset of the unit. This will restore the unit and you might loose any favorites etc that you have stored. Here's how you do a reset.
"With the unit off, place your thumbnail in the groove located under the Garmin logo on the face plate, gently pull off the face place. Press the reset button and turn the unit back on."
Try this and see how the unit works. If it still gives you the same problem then your unit needs repair. I have sent in at least 2 units to Garmin for repair in the last 2 years.
Thanks
Feb 19, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
65 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
