Question about Motorola Mobility RAZR V3m Cellular Phone
Invalid Battery Message
My phone sometimes displayes an "invalid battery" message--what the heck does that mean as there's nothing in the owner's manual about this code? I cannot charge the battery when this message is displayed. 9 out of 10 times, shutting the phone off and turning it back on clears the message. Today I had to R&R the battery to clear the code.
  • wb7tls
    wb7tls Aug 02, 2008
    My Razr failed for no apparent reason but when a replacement phone arrived I got the invalid battery error with the "new" phone and the old battery. I had never seen the battery invalid code (same battery on both phones) with the last phone before it failed. Maybe the phone failure and battery problem was related?
  • rayv333 Sep 05, 2008
    I have the razor v3 and get the invalid battery message. I have changed the battery with a factory battery, cleaned terminals, pulled battery out and card to reboot and did a master reset yet I still get the message and the battery won't charge. Any solutions out there?
My Motorola v325 was having the "invalid battery" message. We took it to Batteries Plus, where we'd bought the battery last year. They said that it happens when there's a blown circuit board in the battery (apparently all Lithium Ion batteries have a circuit board). They actually swapped our old battery for a new one at no charge and it works fine again.
Posted on Oct 22, 2009
I dont know much about cell phones, but im gonna say that maybe you should try and get a new battery for it and see if that works
Posted on Jun 23, 2008
Go to tech support at your carrier it is a problem with certain serial numbers with the battery. If you go to verizon they will replace it with a new one because its a recall on the battery. I have both the V3M and the V325 and they both had the same problem and they said it was due to the recall on them
Posted on Jun 27, 2008
Nokia 5220 invalid certificate
Music player & radio apps were not working the phone displays message" certificate invalid acccording to phone's date
Feb 11, 2014 | Nokia 5220 XpressMusic Cellular Phone
Invalid sim on screen
If your phone show Invalid SIM it means the SIM card is corrupted you will have to change the SIM card.There is no other option.
May 19, 2010 | Motorola Mobility TracFone C139-4 Cellular...
Sometimes my Motorola Rival A455 says invalid battery.what should I do?
You should replace your battery. When a battery is faulty or is getting too worn down, you get that message. First only sometimes, eventually it can be forever.
Nov 28, 2009 | Motorola Mobility Rival A455 Cell Phone
Motorola w220 invalid battery problem
you better change the battery and dont recharge too. charge daily per hour
Sep 19, 2009 | Motorola Mobility W220 Cellular Phone
Invalid battery
Even though the batteries look the same and will fit does not mean they are compatible. I just saw this again at my cell shop today. My razor uses a BR 50. This guys razor needed a BK-70. A BR-50 my partner put in fit, but gave the same message. Your eyes do not deceive you. Make sure the battery model is the same and you are in business. Motorolla batteries have nice big model numbers. I don't have to put my specs on to read it! Happy charging :)
Aug 06, 2009 | Motorola Mobility RAZR V3
INVALID BATTERY MESSAGE
it may mean that you do not have the correct battery inserted in the phone....or the battery may be corroded
Feb 26, 2009 | Motorola Mobility L6 Cellular Phone
Display screen says "invalid battery" All works fine, what does that mean?
your battery may be putting off an incorrect amount of voltage to the phone, and powering it on (yes) but frying it internally (no!)
Meaning, the battery may make it work, but it is not good for the phone.
NGK
Nov 03, 2008 | Motorola Mobility TracFone® V170 Cellular...
Motorola invalid battery
Do this and see if this works
Pull out the battery when the phone is turned ON(remove the battery when the phone is working.)
wait for like 15 to 20 seconds
Put the battery again and turn the phone ON
Jun 07, 2017 | Cell Phones
Invalid Battery
Try open up battery, put it back in & plug in charger again.. wait for a bit then turn phone back on. Hope this helps!
Feb 20, 2008 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3m Cellular Phone Logo
1,181 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
