Question about Roper RT14DKX Top Freezer Refrigerator
Freezer is not defrosting.
After one day ice is beginnig to build up on coil. I can shut off and defrost the unit and it works fine until builds up agaiin.
Roper Model # RT14BKXK003
5 Suggested Answers
  • 828 Answers
SOURCE: Roper Fridge
You have one of the following problems which is indicated by the frost buildup. Your defrost timer has failed, or defrost heater circuit consisting of a defrost heater and defrost thermostat. Start at the defrost timer. May be located in the fridge compartment near the temperature controls. There may be a recess through which you can turn the dial SLOWLY clockwise until you hear one click. the freezer will be in defrost. Wait 18-22 minutes and the freezer should defrost and restart into cooling. If it does not restart after 30 minutes turn the screw clockwise again one more click and it should restart.
If you had to turn it again to get it to restart the timer is bad and needs to be replaced. If the timer restarted the cooling mode after 18-22 minutes and defrost did not take place your problem is in the heater circuit.
Posted on Jun 09, 2008
  • 619 Answers
SOURCE: Ice build up in freezer...Auto Defrost not working
If it is a magic chef the model number will be on the back of the fridge and will have to order the exact defrost timer for this model. Only place to get will be from
Posted on Jan 31, 2010
  • 351 Answers
SOURCE: We have a Roper side by side, it is only 4 yrs
hi do you have a volt ohm meter pull the back out of freezer check the element see if it has continuity if so it may be the timer witch should be somewhere near the thermostat hope this helps you jim
Posted on Oct 11, 2010
  • 2341 Answers
SOURCE: Excess water dripping into refrigerator from
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Posted on Aug 09, 2011
Norcold 1200 fridge only getting to 50 degrees will work fine for a few days then get warm if i shut it off for a few hours and turn it on again it will cool for a couple of days then problem retur
Sounds like your defrost cycle has failed. Since the unit is running fine for a while before warming up, this can rule out your circulating fan. Your defrost cycle is operated by a defrost timer or your motherboard depending on the age of your refrigerator. When your refrigerator goes into defrost, it turns on an electric heater that melts the ice from your coil in the freezer. When your defrost time or electric heater fails, it allows ice to build up on the coil in your freezer which blocks airflow which causes your cooling compartments to not maintain temperature. Hope this gives you an idea what to look for and a guide on where to start looking
Jan 20, 2018 | Refrigerators
My refrigerator is cool but not cold. My freezer is keeping things frozen but takes longer to form ice (no ice maker) and my ice cream is soft. I hear the motor running and I do not have any frost build...
Hi Nancy,
I bet you've got all kinds of frost / ice behind the plastic cover that protects (and shields from view) the cooling coil in the freezer compartment.
You probably have one or more: defrost timer, defrost terminator or defrost heating element that has failed. Call for service - or empty the fridge and unplug with door open for a day - ice will melt and when you plug in again it will work just fine. Until frost builds up again that is.
May 12, 2015 | Frost Refrigerators
Possible problem with ice build up and fridge doesnt get cold enough to store food. Freezer works fine.
The noise is due to the ice build up in your evaporator. The evaporator fan blade is rubbing against the ice build up. This can is designed to turn off when you open the door. As far as the defrost problem it can be your defrost bimetal thermostat, the defrost timer/control or your defrost heater.
Nov 07, 2013 | Samsung Refrigerators
Defrost Timer or the Defrost T-Stat?? Also Model # VCSB480SS06
no defrost timer runs through control most common issue is limiter
Oct 22, 2017 | Viking Professional Refrigeration: 48"...
My refrigerator/freezer compressor never shuts off. What could be the problem? It is a GE model# TBHA22ZRE.
If the compressor is not shutting of sometimes this is relative to the machine trying to reach the correct tempreture in the freezer area but not being allowed to due to an issue like a defrost issue. In order to check if your unit is haveing a defrost issue you would need to remove the rear panel on the inside of the freezer. Yes this does mean all the food and the racks have to come out as well sorry. Usually there are a couple 1/4" screws that hold the rear panel in place. After removing the panel this would then give you access to the evaporator coil. If when you remove the rear panel you see any type of ice build up either on the coil or below the coil or the fan above the evaporator coil moving sluggishly and not spining at a hi-speed this would be termed as a defrost issue. This is caused by either the defrost thermostat, the defrost heater, and the defrost timer or in some units instead of the timer they have an adaptive control board. You would first if you had a defrost issue use a hair dryer to defrost any ice build up on the evaporator coil. After defrosting the coil then you would grab your handy multimeter and perform a continuity or ohms test on the defrost thermostat which is a small disc like two wire object usually attached to one of the copper lines going to the evaporator coil. Located one or both of the side would be the connection for the defrost heater as well and the same test can be performed to assure that this part is in proper working order. Usually it is the defrost thermostat that is the issue that causes the ice build up in most refrigerators that I repair about 85 percent of the time it is mainly due to this being the fault. If you find that both the defrost thermostat and defrost heater are fine and you have no ice build up on the evaporator coil message me back for further diagnosis. There is also a test to check the other parts mentioned as well but it is very lengthy to describe how to test these parts and I will await till you have firstly checked for the ice up issue on your evaporator coil and if so then tested the defrost thermostat and the defrost heater. I await your reply if you have any further questions and please remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future Thanks
Aug 05, 2011 | GE GTR11AAP Top Freezer Refrigerator
I have a side by side refrigerator,which the freezer started to melt and the compressor wasn't going on. I have cleaned the coils under the fridge so they are clean and the only way I can get the...
One of two things is happening either your thermostat is on its last legs or you are getting a ice build up in the freezer area, that is telling the thermostat that the freezer and refrigerator is cold enough.
I would suggest you remove the food from your freezer side; remove the shelves; remove the inner back panel and see if there is an ice build up. If there is, then your defrost assembly is not working and will need replacement.
The good news is that if you defrost the unit (a hair dryer will speed the process) you can use the refrigerator until the defrost assembly arrives. And the defrost assembly is relatively easy to change out.
Jun 06, 2011 | Kenmore Side by Side Refrigerator
The freezer side is working but no cold temperature in the fridge section of our side by side door with water and ice dispenser kitchaid fridge. Wonder what the problem is?
If the refrigerator is in defrosting mode, the freezer compartment temperature will be less cold than usual. Wait 20 minutes, and you should be able to feel cold air blowing in the bottom of the compartment. If you have frost on the freezer coil, you probably have a defrost problem. Your freezer should go into a defrost cycle about twice a day. When this happens the compressor and fans shut off and a defrost heater in the freezer coil will turn on heating away the ice. This usually last 10 - 20 minutes. If the defrost coil doesn't defrost it will become a solid block of ice and this will in turn block the air from blowing into your refrigerator compartment. There are several things that can go wrong with the defrost cycle such as the defrost timer, defrost heater, or the defrost termination thermostat.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting
Jul 19, 2010 | KitchenAid Refrigerators
Defrost does not work properly, continues to freeze up element in lower freezer compartment, shutting down cooling in upper refrigeration unit. We continue (bout every two weeks) to take wall unit off and...
i noticed ice build up towards the bottom right corner of the back panel (in freezer)....i diconnected power...took the back panel off had frost on it....coil was iced up.... then on the back of the refrigerator i accessed the control board....plugged the power back on ...i jumped the line to the heater...heater didnt work....then checked resistance through the heater (checked ok)....
it came down to me replacing the defrost thermostat which is in series with the heater....defrost now works fine ...which is every 60hrs for 45 minutes on mine.
Oct 01, 2009 | Refrigerators
My refrigerator is 4.5 years old and the problem is that the freezer has ice build up in a matter of days, so much that it prevents air flow from the freezer below to the fridge above. I have defrosted it...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Amana 19 cu ft Bottom Mount Refrigerator,...
Roper RT14DKX Top Freezer Refrigerator Logo
60 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
