Question about LG ADR-620N CD Player
No Audio hello sir! I'm inputing an audio source (mini disc player) via the CDR left and right inputs and then atempting to record or burn a copy of the mini disc. However all thats happening is the 'no audio' message. I have selected the correct 'input' using the input selector but still no luck. I also have the same problem with any attempt to record off a CD in the playback (CDP) tray... I'm using CDRW's.. what am i doing wrong? thanks! Tim
  • feboking Sep 06, 2008
    well, it was a solution written in a language i dont understand!
    thanks anyway
Tienes que comprar cd para grabacion que diga audio digital si no no los quema
Posted on Sep 05, 2008
How can I record a music cassette to a music disc on my Magnavox DVD recorder/ VHS --Model # ZV427MG9
You can't burn a CD-A with the ZV427MG9. The unit will not burn to a CD to play in a CD player.
You may be able to record the audio to a DVD with no video source. Connect your cassette player to the Line In audio ports (L/R) at either the back or front of the unit. Depending on your cassette player, you may need a 3.5 mm M to RCA F/F adapter to connect the RCA audio cable to the cassette player's headphone jack. Do not connect a cable to the video input of the composite input unless you have a video on a camera or something to play back. This means that the recorded video may say "No Signal" or will be black or static. (Note: this may not work with this signal issue.)
Set the unit to record to DVD on L1 or L2, as needed, by pressing Source on your remote. Advance the cassette to where you want to record. Press Rec on the DVD unit and then press Play on your cassette player. If you want to identify tracks, Stop the recording and play back and then press Rec and Play again. You are at risk of having issues with the volume during the recording. Clipping of overly-loud sounds and distortion is possible.
When done, finalize the disc, if desired, to play the disc on other DVD players.
If you want to make an audio CD, you would be better off using a computer and connecting the cassette player to the Line In jack of the computer. You do have to make some adjustments to avoid recording the default Microphone input. Use a program like Audacity or any other audio editing program. Record the signal and divide it into tracks, if needed. Now you can filter out any distortion as well. Then save as a WAV file. Use a different program to burn the WAV files to a CD-A. (This must be burned as a mastered disc; my attempts that worked on an older CD player failed if there were gaps between the tracks. Lots of programs will do this; Roxio Creator is one option.)
The manual for the ZV427MG9 is available here: http://download.p4c.philips.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf .
I hope this helps.
Dec 31, 2012 | Magnavox Televison & Video
OLD AUDIO TAPE TRANSFER TO DVD FORMAT
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 24, 2008 | Audio Players & Recorders
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
I would like to hook up my 50 disc CD player to this unit
That should be easy. Not knowing what model 50-disc unit you have I'll assume it has at least one analog Audio Out RCA pair and maybe one or more of the possible digital outputs that correspond to the digital inputs on your CDR.
Simple: compatible Outs on the source go to compatible In's on the recorder. Ta-da!!!
Apr 21, 2010 | RCA CDRW120 2-Disc CD Recorder
Converting Audio Cassettes to CDs
First off I assume you have the manual for you're 5700. if not a PDF copy is here
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000027911.pdf
Assuming you have a standalone tape deck that has phono inputs and outputs connection and recording recording should be easily achieved.
Forget the coaxial unless of course your tape deck has digital outputs.
Assuming it hasn't just connect the two output sockets from the tape dec which may be labelled REC out left and REC out right to the Line in (L) and Line (R) of the CD recorder.
The physical setup is now complete.
The increment level they refer to in the manual offers you a choice of 3 final decibel output levels in other words how loud it will be when it is finally recorded onto the disc.
the last paragraph on page 16 is relevant to the setup described above.
Page 15 of your manual is all you need to achieve tape transfer to CD.
follow the steps below and choose ANALOG the source to be played is your tape deck so once the process has begun press the play button on your tape deck and you should get a decent recording. Leave everything else at their default settings until you get a better understanding of how to tweak your recordings.
Personally I transfer audio tapes directly to my PC and Audio edit them until they are perfect but I've been doing this for years.
Good luck
here's a snippet
To record from an external source:
1. Turn power ON.
2. Place a recordable audio disc (CD-R or CD-RW) label side up
in TRAY II.
3. Close TRAY II. (When a blank disc is placed in TRAY II, the display
will show BLANK.)
4. Press INPUT until the source you want to record is selected.
DIGITAL OPTICAL:
record a source connected to the DIGITAL IN (OPTICAL) terminal.
DIGITAL COAXIAL:
record a source connected to the DIGITAL IN (COAXIAL) terminal.
ANALOG:
record a source connected to the analog LINE IN jacks.
5. Select the desired mode of track division (track number
assignment) by pressing the MANUAL/AUTO button (see the
ADVANCED RECORDING section for more information).
6. Press the RECORD button.
The unit enters record pause mode.
The PAUSE [ ] icon and REC blink on the display.
7. Press the PLAY (ENTER) [ ] button of TRAY II to start recording.
8. Play the source to be recorded.
• During digital recording, if the input signal stops for 5 seconds,
recording will stop.
• During analog recording, if the input signal stops for 20 seconds,
• If the unit detects copy-prohibit signals during recording,
CAN’T COPY appears on the display and recording is stopped.
To stop recording: Press the STOP [] button
To temporarily pause recording: Press the PAUSE [ ] button.
Remember that every time recording is paused or stopped,
a new track number will be assigned.
Jan 11, 2009 | TDK DA-5700 CD Player
Recording audio only from an HDTV concert
Have a look at the manual for your AV receiver, you may find that you can change the digital output format between DTS mode and PCM(audio) mode. It needs to be in PCM(audio) mode for your CD recorder to be able to record digitally. If that doesn't solve it I can only suggest recording in analogue mode, i.e. taking a stereo analogue signal from your receiver to the analogue inputs of your CD recorder.
Hope this helps
HifiJohn
Jan 04, 2009 | Harman Kardon CDR30 2-Disc CD Recorder
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
Teac rw-cd22 burning problem
You were right! I changed the cd and it does not do DA:D2
Feb 13, 2008 | Audio Players & Recorders
No Audio 10 Error
What have you got hooked up? Another CD, tape outs from an amp or a record deck? No audio is a strange message to get, like you say you're using an audio cdr and that's usually what it means. What about if you press record with *no* source connected? Unit should record 20 seconds of silence then cut off.
Jan 20, 2008 | Philips CDR765 2-Disc CD Recorder
LG ADR-620N CD Player Logo
165 people viewed this question
Top LG Audio Players & Recorders Experts
Electro Med Services...
Brian Sullivan
Brian Sullivan
Iron
Iron
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
