Question about HP Photosmart C6180 All-In-One InkJet Printer
Phone off hook message
This message can't be resolved. Have checked all connections, modem and router working, phones in house have line separators, but fax won't work. Phones obviously not off the hook since they work fine.
  • mcknight13 Jun 23, 2008
    Error message is "Phone off-hook"
  • 85 Answers
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver is off the hook (the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message. Checking the phone line The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time. If a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
Problem still exists If the problem still exists after performing the steps above, the line interface unit (LIU), the part that the phone line plugs into, may be defective or the HP product may need to be serviced.
Posted on Jun 23, 2008
    Guru:
  • 859 Answers
1.) Are there two jacks on the back of your Printer?
2.) Does this line you connect through share the same line s your router and have the DSL splitter on it?
3.) Does you PC connect to the outside phone line by passing through your printer?
4.) Does all these lines, if sharing with your DSL line, have DSL adapters on them?
Regards,
Worldvet
    Master:
  • 638 Answers
This could be problem in the internal wiring or board.try using the fax with some other phone line.it may solve ur problem.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • HP Master
  • 6,487 Answers
Can you fax using another unit if you can so that can really be a problem with that device, But if not so it can be a grounded telephone line.. You can also check this link http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu01832&lc=en&cc=us&dlc=&product=58557
Hope that helps.........
    Sergeant:
  • 260 Answers
A phone off the hook message simply means an open line. It is the opposite of a shorted line. This could be a wiring issue very close to the unit itself. Does the phone work on the fax? Can you plug a differnt phone into the fax line?
    Genius:
  • 3,422 Answers
Can you please let me know the error message.
Diagnostic light keeps blinking
Check the LED lights that are blinking on the front of the DSL modem. Check the "Internet/Online" LED and make sure it is blinking green or a solid green. If this LED is not blinking, then the modem is not getting a phone signal, or the service is out. Remove the line and check it to make sure that you're getting a signal.
Check to see if filters are connected to the phone lines that are all around the house. These filters separate the phone line from the DSL line so that the lines do not crosswire and disturb the Internet connection or the phone connection. The DSL is usually shipped with a couple of phone filters. These phone filters can be purchased at many electronics stores or provided free from your Internet Service Provider.Check to see if the modem is connected to a wireless router. If the modem is connected to the router, try disconnecting the router and connect the modem straight to a computer. If the modem is also a multi-port wireless router, then connect the computer to a different port on that same router.Reset the router if the previous steps do not resolve the problem. Follow the initial set up instructions given to you when you first installed the router. Perform any firmware updates that might be needed once online, and use the discs that came with the modem.
Feb 07, 2012 | Cisco RVL200 Router
Busy signals on all handsets, cannot call or recieve calls
Are you refering to a cellphone or a landline phone
Sep 13, 2008 | Lands Phones
My house computer is being fixed out of the house, now my wireless computer isnt working, i have to connect to the phone connection. Is that the way it should be?
Check All your connection Reset your Router in the back you will see a little hole with a button press on it for 10sec.. Then got in your Sitting Control Pannel add and Remove ...Remove your Belkin software and re start your PC then re install your belking software for Any PC You may have a 4 hub conection ... So make shure your Modem are connected on the right Hub on your Router and the phone line to the modem Because See The modem tranmit is data to the router the transmit on any pc connected ony your Router ...good luck
Sep 22, 2010 | Belkin (F5D7231-4) Wireless Router
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
Don't have home phone and looking to buy router/modem.
Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
May 08, 2009 | NetGear DG834G Router
Connecting router to dial up
I don't believe that router is designed to be hooked directly into the phone line. That would be your problem. The process is much more complicated than simply plugging your phone line into the router instead of the laptop.
Feb 27, 2009 | Belkin (F5D7230-4) Router (587009)
CAN'T GET FAX WORKING.
If it's answering on your main number, then you are not plugged into the fax jack. You should have a separate phone jack for fax. If you have internet phone there should be a second jack on the back of your phone box. You can test that you have a functioning second line by plugging the fax into it and using the fax unit to dial your home number.
Jan 05, 2009 | Dell 926 All-In-One InkJet Printer
How to change Linksys wireless router?
When you get cable internet, the cable company provides you with a modem (usually). From the cable modem you can hook up the Linksys router with an ethernet cable and it will work just fine. Hook the router up to the desktop or laptop with another ethernet cable if you need to make changes to the router security or whatever. The router address is generally 192.168.1.1. YOu can type that address right into the internet address and you router page shoud show up. If you have been using the Linksys router with the phone line all you need is to connect it to the cable modem to work. An ethernet cable is like a telephone line with a fatter connecter.
Nov 29, 2008 | Linksys Wireless-G WRT54G Router
No internet signal between router and desktop pc.
have you plugged everything in with the modem off and the router off?
have you tried unplugging the linksys for a sec then plug it back in?
also have you checked the pin connection on the plug on both the computer and the router?
what are the lights indicating?
Oct 14, 2008 | Computers & Internet
I had my grandson hook up the router and all seemed to be working fine, but this morning I found I have no phone service. Can you tell me how to remedy the problem. Thanks, Betty Mahoney email: ...
The router has nothing to do with phone service - it's the modem that's plugged into the phone line. Unplug the modem from the phone line. If you don't get phone service back within 30 minutes, use a different phone to report loss of phone service to the phone company. (Depending on the company, it could take up to 30 minutes for the computers to restore service after a short has been removed.)
If that's the case - that unplugging the modem clears it up, call the phone company's internet tech support number.
w2pmx ::)
Sep 10, 2008 | Belkin Computers & Internet
HP Photosmart C6180 All-In-One InkJet Printer Logo
185 people viewed this question
Ben Johnson
