Question about Brother IntelliFAX 560 Plain Paper Fax
Print Fax Confirmation
I sent a fax yesterday from my Brother Fax Machine 560, but I didn't get a confirmation printed, as the cartridge ribbon needed to be replaced. I would like to print a confirmation today, now that I have installed a new ribbon, but I cannot figure out how to do this, as I do not have a manual. Can you help me?
Thanks!
    Novelist:
  • 158 Answers
Press MENU button, then 5 on the numbers keypad. you should be able to scroll through a list using the up and down buttons. #1 is the HELP LIST, #2 is AUTO DIAL, #3 is FAX ACTIVITY which shows LAST INCOMING AND OUTGOING faxes,#4 TRANSMISSION,prints a TRANSMISSION VERIFICATION REPORT of the last transmission. #5 USER SETTINGS lists your setting. To select your report, select the REPORT NUMBER, press SET, then START, to print
Posted on Aug 09, 2008
How can I get a FAX Confirmation printed out on the HPJ4680?
If you require printed confirmation that your faxes weresuccessfully sent, follow these instructions to enable fax confirmation beforesending any faxes. The default fax confirmation setting is Off. This meansthat a confirmation report is not printed for each fax sent or received. Aconfirmation message indicating whether a fax was successfully sent appearsbriefly on the control-panel display after each transaction. NOTE: You can include an image of the first page of the faxon the Fax Sent Confirmation report if you choose On Fax Send or Send &Receive, and if you scan the fax to send from memory To enable fax confirmation
1.Press the (Setup) button.
2.Press right arrow to select Print Report, and then press OK.
3.Press right arrow to select Fax Confirmation, and then press OK.
4.Press right arrow to select one of the following, and then press OK. Off Does not print a fax confirmation report when yousend and receive faxes successfully. This is the default setting. On Fax Send Prints a fax confirmation report for every faxyou send.
OnFax Receive Prints a fax confirmation report for every fax you receive.
Send& Receive Prints a fax confirmation report for every fax you send andreceive
Jan 10, 2011 | Office Equipment & Supplies
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Confirmation page needed
Press MENU - 2 4 1 then you can choose to have that feature ON or OFF. the +Image means that it will also print a copy of the first page sent so you can actually verify the document sent.
Mar 31, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Received confirmation
Sent confirmation reports are available within the fax machine.
Theoretically if the fax has been successfully sent, it should be successfully received on the other end as well.
But unfortunately there is no confirmation for successful receipts, unless you are using IP based fax transfer.
Mar 31, 2010 | Brother IntelliFAX 560 Plain Paper Fax
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
each transaction.
1. Press Setup.
2. Press 2, and then press 1.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Print confirmation
Scroll through the menus and select CONFIRMATION
Sep 19, 2008 | Brother IntelliFAX 4100 Laser Fax
Print confirmation
On the top right of the machine select Reports
In the center of the machine use the right arrow key till in the window it says #4 Transmission
It will print you the information for the last fax that you sent.
Jul 23, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother Fax 560 will not stop running the cartridge. The cartridge can be replaced, the door closed and it will not stop running until the cartridge is empty. How can I fix this problem?
Unfortunately there is no fix for this problem as the system board is corrupted. Try powering the machine of from the wall socket and then powering back on. If this doesn't work the machine will be more cost effective to replace.
One question though is it an original cartridge that is installed if not install a new original ink cartridge.
Cheers J
Jan 05, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFAX 560 Plain Paper Fax Logo
291 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
