Question about Jabra T610 Consumer Headset
Jabra 200 no sound
Hi ive connected my hands free kit to my phone, i have found i cn talk to ppl but i can not hear wot they are saying have no sound at all. going bo to themy phone i ca hear them when i turn of the head set but again turning it bk in i cant hear them through it! any ideas, i have tried delelteing the connection and setting it all up again and turning up the volume but still i have nothing.
any help would be great!
SOURCE: Jabra connection
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Posted on Feb 13, 2008
SOURCE: Jabra BT 350
Make sure when you turn the bluetooth headset on that the blue light stays on and doesn't blink. When the light is steady it's in pairing mode. Then go to the bluetooth settings menu on your phone and select add device. Type 0000 when it asks for a passkey. Click ok when you see pairing successful. If that doesn't work call customer service at 1-866-465-3494.
Posted on Feb 22, 2008
  • 3 Answers
SOURCE: Jabra BT 350 has stopped connecting
Hey everyone! I had the same problem, and I actually got it to work again! I hope these directions will help you get yours to work (from the manual):
1. Put the headset in pairing mode
• Make sure the headset is off.
• Press and hold the answer/end button until a solid blue light comes on. <== THIS IS VERY IMPORTANT! HOLD THE BUTTON UNTIL YOU SEE A SOLID NON-BLINKING LIGHT! (This is where I was going wrong with the directions.)
2. Set your Bluetooth phone to ‘discover’ the Jabra BT350
Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT350
Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN = 0000 (4 zeros).
Posted on Oct 27, 2008
SOURCE: unable to connect jabra t5330 to a cisco ip phone 7941G headset jack
You can solve this by connecting your phone inline.
On the back of the phone where the phone handset plugs into, plug one end of the jabra headset wire & connect other end to the 2nd position (marked by phone & handset). Now plug the handset wire from Ip phone to the 1st position (marked by handset) in the jabra headset. Now you are good to go.
When the phone rings lift the phone handset and answer it with your jabra headset. You can't use jabra with 7941 without lifting the handset on phone.
Posted on Jan 28, 2009
SOURCE: jabra bce-250
how to connact nokia 6300 with jabra bce-205 wireless headset
Posted on Feb 06, 2009
Can you please connect my hands-free speaker phone so it works consistently?
In this link you can find how to connect the hands-free so it can work as you need it.
Regards,
Maya
Motorola Support
Oct 21, 2015 | Motorola Mobility M930 Cab Phone Handsfree...
Jabra talk ps3 problems
i got the same problem. hope sum1 knows whats wrong cuz i dont.
Aug 09, 2012 | Jabra Cell Phones
How do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
How do i pair my hfs001
Hello, Press and hold the "Answer/End" button for about five seconds. When you hear "Pairing Mode," the speaker is now discoverable by other Bluetooth devices. Turn on your cell phone;s bluetooth connectivity. Once your cell phone has found the HFS001 it will ask for a pairing code the code is "0000". The phone will then connect to the HFS001. Enjoy your hands free experience!
Mar 05, 2011 | Jabra Bluetooth Car Kit with Night Driving...
Jabra BT620 Microphone dose not work with Soft Phone on My PC
Well, I got the same problem the days before, and after some trying, I've solved.
I'm using the Toshiba bluetooth adapter, too. You see, when you want to make a new connection with your bluetooth device, you may either use the Express Mode or the Custom Mode. Go with the Custom Mode, then, there appears the Jabra BT620. After input the 0000 code, you may select the services from 3 options. There, you can find the headset or hands-free option.
Go with that, than you may have your Jabra BT620 as a microphone!
Sep 09, 2008 | Jabra BT620 BLUETOOTH STEREO HANDS-FREE...
Jabra bce-250
Nov 27, 2007 | Jabra BT250 Consumer Headset
Connecting to a jabra hands free
once you have found it it should then ask for a pin code which is either 1234 or 0000
once this is accepted then they should be paired completely
Nov 25, 2007 | Cell Phones
Cant hear
I have the same problem. The lights are on, it's paired, and my caller can hear me. but I cannot hear the beep from pressing buttons on the jabra, nor can I hear anything from the phone.
Oct 31, 2007 | Jabra BT500 Wireless Headset
No sound
Had the same problem with the BT250v 'connected' to my Nokia 6021. When connected to my notebook, the 250 did produce sound, so decided the Nokia was the problem. Fixed the problem by doing a full reboot of the phone like this:
Jabra: Turn off the 250
Phone: Delete the BT connection to the Jabra (in BT settings)
Phone: Switch off BT
Phone: Turned off the phone (I've even removed the battery)
Phone: Turned on the phone
Phone: Switch on BT
Jabra: Turn on the 250 for detection
Phone: Look for audio devices
Phone: Connect to Jabra
Problem fixed!
Sep 02, 2007 | Jabra BT250 Consumer Headset
Jabra T610 Consumer Headset Logo
67 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
