LG Ally Cell Phone Logo
Posted on Nov 26, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lg l I will not pair with plant tronics headset
RONALD CARTER JR
Level 3:
  • Master 438 Answers
  • Posted on Nov 26, 2010
RONALD CARTER JR
Master
Level 3:
Answers
438
Questions
0
Helped
91561
Points
1345
Hi sarzim take the battery out of the lg phone .. Once youtake the back off check to make sure the is no dirt or any foreign obstacle in the contacts . Next put the battery back in the hone. The next thing you want to do is go into the settings and go to wireless settings. Next go into bluetooth make sure is is in sidcoverable mode scan for devices. ON the plantorics make sure that bluetooth is flashing back and forth two colors. Once all this is done the phone and bluetooth should pair together.You need the pplantroincs blue tooth to have a good charge and the liightd flash back and forth it becomes one color when it is pair with the phone.the code is 0000.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
1helpful
MY LG tone headset blue light does not go off and it won't pair?
Try to pair it with another device so you can diagnose if it's the blutooth of your LG Headset.
By the way, my experience with LG Headset is that it won't pair withh all bluetooth smartphones.
What is the pass key code to pair lg tone pro HBS 750 to my ps3?
1. You need to charge your headset to full capacity using the charger supplied with it.
2. Disconnect it i.e. your headset from the charging source.
3. Press and hold the "Call/Send" button located on the front of the headset for like 5 seconds to activate pairing mode.
4. You should notice an indicator light begin to flash. Your headset is in pairing mode already.
5. By now, you must have had the bluetooth on your PS3 on.
6. Have both devices pair with each other.
LG headsets use a pairing passkey of four zeros ("0000").
I have a Tao Tronics hedset TT-BH01 and I can't get it into pairing mode. I have tried for 2 days.
I don't know if this is the problem you are having, but I had trouble figuring out how to get the headset into pairing mode. The problem is the manual is wrong! It says to turn the headset on, and then hold the function key for 8 seconds to turn on pairing mode--but holding the function key for 5 seconds just turns it off! After searching under some other models, I figured out that you have to hold the key for 8 seconds while it is off and then it will go directly into pairing mode. Hope that helps!
1helpful
Lg tone hbs 730 manual and user guide
can you pair this headset with different devices? Meaning, it is paired with my husbands phone, and I'm wanting to pair it with my phone when he isn't using it.
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Can the LG HBM 550 be paired a second time to another phone?
YES IT SHOULD BE ABLE TO BE PAIRED TO AS MANY PHONES AS YOU WANT BUT WILL ONLY WORK ON ONE AT A TIME.
2helpful
3answers
User manual for LG HBS-110 bluetooth headset
To pair the headset with your phone:
Turn on the headset. Then turn on bluetooth in your phone and search for bluetooth device.
When your headset is detected, just select it and follow onscreen instructions to pair it with your phone.
After putting the headset into pairing mode, my phone (also an LG) will not recognize and pair with headset. Also tried another (non LG device) and that would not pair either? Headset used to work with...
According to a VzWireless Tech, take the battery out for 30 seconds and then put it back in. The phone should reset itself to pair the bluetooth headset with the phone. If that does't work remove the device from the phone and start from step 1. I removed the device from the phone then I took the battery out for 30 seconds. Then I paired the bluetooth and followed the next steps to complete the sync.
19helpful
4answers
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
New Cell phone, old headset - don't know the passcode
hiii
i have sonyericsson k750i but am not able to connect lg hbm 300 headset
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
