Shure SM58 Professional Microphone Logo
Anonymous Posted on Jun 23, 2008
Shure sm58 some genius friend of mine took apart my shure sm58 and gave it back to me in a zillion peices. is there anywhere i can get an exploded view to put it back together again . i will NOT pay someone a ton of money to put it back together when i could do it myself. can anyone help? thanks danmny [email protected]
  • gharvey Jan 15, 2009
    So how do you get the parts out of a shure? There is like a liquid nails kind of stuff that holds everything in the barrel. Do you have to heat it or something?
    Garland
Anonymous
Level 3:
  • Master 1,512 Answers
  • Posted on Jul 04, 2008
Anonymous
Master
Level 3:
Answers
1512
Questions
13
Helped
829703
Points
3938
Hi danny
There not that much to take apart on the sm58. On page 2 of the user manual there is a wiring diagram to reconnect wires. the grill wind filter part screws on. The socket on the bottom is secured with a screw.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
  • Matthew Crowson
    Matthew Crowson Jan 23, 2011
    Thank you, sir....You Rock!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 19, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
8005
Points
I got a shure sm58 from my friend... I was cleaning the dust on the mic, and I unscrewed it but then it doesn't work, the internet says that the green and yellow wires are usually disconnected when unscrewed... Should I take the mic apart myself? But it says the warranty will be cancelled... or should I just fix it myself...? If it's really the wires how do I connect them back in place cause one you do then when you screw it back it's gonna be lose again right...? I just got it for a week and I am really sad my friend flew away and there's no help :( Can anyone help me...
Shure SM58 not working. Tried on various pieces of equipment using various configurations of cables and not a sound. Took unit apart and all wiring appears to be intact. The mic has been unused for several...
The SM58 is a dynamic mic. It's actually a very simple device. Thus, it doesn't "degrade". If an SM58 fails, it usually fails catastrophically. Now, the problem for is that you don't know if the failure is in the handle (which includes a transformer) or the cartridge).
You can order a replacement cartridge from Shure and solder it in place, but might be better for you to just send the mic to Shure. I believe they will just replace the mic with a new one for their service fee.
www.shure.com/service
Shure SM58 A singer has joined me with her own SM58 ,i have to turn the volume up much higher on mine ,with a more muffled sound .This is causing a prob .The PA is a Yamaha Stagepas 300
Please get the microphones checked seperately If there is an impedance difference orr if the coil is damaged then this difference of sound is possible.
So just check it out or else replace the mic.
Shure sm58 mic stopped working ...
Check the wire connections where the xlr cable connects.
2answers
Where to buy a the swivel adapter for shure sm58 and shure wireless lx2 sm58
You can buy the swivels from Beyer, they have several sizes.
In my opinion he best you can get.
Regards,
Gerard
Need to clean my sm58 grills
Did you try to unassembled the microphone?
Get the top section off, and then take it apart to separate the transducer. Some of these models are a task in themselves to take apart and reassemble.
Once you are left with the screens, these could be washed with water and dried off. Then you simply re-assemble again.
Jerry G.
1helpful
HELP!!!!! SM58 (with switch) had no sound after slightly screwed
I would recommend returning the mic for factory warranty. It's the safest option.
By trying to fix it yourself, you risk the wires becoming even more damaged. You would probably have to solder them back to the connectors. It takes a steady hand when trying to solder on a wire to a micrphone connector, (I've tried a few times). The fact that it's so tiny, and located very near the diaphragm, it is a very risky operation.
If you do manage to get them back in place, it is not likely that they will disconnect again if you use solder once you try to put the cap back on. The problem is that you should never open it again. Harsh punishment, especially if it's under warranty.
Top Shure Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Cairns
Mike Cairns
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
