Question about Whirlpool Washing Machines
WTW5800SW, safety switch needs replacing. How do I do it?
  • 413 Answers
  1. Before replacing the switch check the lid hinge screws on the left side, if they come loose the switch will not activate.
  2. As part of the lid hinge, there is a rod under the cabinet on the left side that can be bent upward by holding the lid open and pushing on the rod.
  3. To replace the switch, insert a putty knife under each corner, push to release a latch. With console lifted, the switch is snapped into the cabinet on the left side.
Posted on Jun 24, 2008
Washing machine will not wash
Be more descriptive of your problem
Nov 06, 2013 | Whirlpool WTW5800SW
In rinse/spin cycle the washer sounds like a helicopter.
there must not be enough water in it. go to a place to have it checked out.
Aug 09, 2013 | Whirlpool WTW5800SW
Bosch Maxx 1000 front loader trips safety switch
You have a circuit that is overloading and causing the safety switch to trip. It could be a problem in your wiring harness, thermostat, control/selection dial, anywhere. Where ever it is you need to have a qualified maintenance person who is trained in that particular machines wiring to check it out. By it kicking your safety switch out it is telling you that there is an Electrical overload some where in your wiring or it's components. Without the safety switch a fire is very possible. I am not an expert or even familiar with your machine but years as an Instrument Technician I know instruments are placed in devices to inform, regulate and protect you and your equipment. I would check for a shorted out Electrical switch, these switches are a type of solid state switch. They will be mounted in different places in the circuits and are round with two wires attached to them with blade type connectors. Here again you need a serviceman who is familiar with the particular wiring harness. Try going to the Mfg's web site for help. Some have a free Q&A section with a live chat box. This is not intended to solve your problem but to help guide you in the proper direction to get a solution.
Apr 03, 2012 | Washing Machines
Recently my Whirlpool 115 volt dryer takes a long time to dry a
either u have a kinked venting or bad air flow,,, go outside it should be blowing well , do u have a long vent or goes up... if ur vent gets clogged or blocked can cause the problem u are having... if possible undo venting and blow it outside through pipe with leak blower and replace ducting hose from dryer to wall if built up with lint.... if not a venting problem then its possible it could be an operating thermostat inside the unit... hope this helps let me know
Apr 08, 2010 | Whirlpool WTW5800SW
The air pressure line fills with water sometimes and causes the washer to overfill and the water just continues to run all over the floor
Remove the line from the switch and blow it out. Make sure that tubing is going down the little channel with the wiring harness so it wont get pinched. Re connect the tube tight to the water level switch and pump out the water before retry. I have repair photos HERE
Feb 27, 2010 | Whirlpool WTW5800SW
Washing machine will not advance through the wash cycle, machine will fill tub and begin wash cycle but will not move on to the rinse cycle. The washing machine will remain in the wash cycle and can only...
Hi, Your timer motor burnt out, or timer faulty, remove top back panel (back of timer) and check timer motor, if timer motor are built-in (electronic type) you'll have to replace timer, or if timer motor can be remove, replace it, check back of timer, (knob you turn to change cycles or programs) locate timer motor, you can check appliance store to purchase timer motor, or let mechanic check, surely it's your timer motor or timer, check let me know,
Aug 12, 2009 | Whirlpool WTW5800SW
Won't spin unless I give it a spin by hand, with the lid open and the safety switch jumped. water pumps out of the machine OK please help. kern.
The problem is your spin clutch on the transmission is worn out. You will need a repairman to do this.
May 16, 2009 | Whirlpool WTW5800SW
Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
Feb 17, 2009 | Whirlpool WTW5800SW
Whirlpool WTW5800SW doesn't always agitate
Sounds like you may a bad lid switch. Do you hear any clicking noise when the lid gets shut. The clicking noise is the lid switch activating.
Dec 26, 2008 | Whirlpool WTW5800SW
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
