Question about Xante CL30 HSE Laser Printer
380 Paper Jam
As soon as I turn on the CL30, the menu displays "OPEN SIDE COVER - 380 Paper Jam. We have gone thru the process steps many times. No Paper Jam... Has a sensor gone bad?
There could be a small bit of paper stock in sensor
near the bypass tray.
Posted on Dec 10, 2008
My display screen on my Brother MFC-240C says "Paper Jam" and there is no jam. How do I reset it?
You press Menu/Set 2,0,3, then press up/down arrows set faxibility to on. Press menu/Set, then press up/down arrows to turn call waiting on or off. Press Menu/Set and lastly press Exit/Stop.
Sep 12, 2012 | Brother Multi-Function Center MFC-240C...
I HAVE A CANON PIXMA MP830 INK JET PRINTER WHICH HAS A PAPER JAM CAN YOU HELP
Here are the basic steps that can resolve your issue.
- Paper jam in the Paper feeder or in the output slot
pull out the paper slowly, if the paper tears open the printer cover(scanning unit) and remove the paper (careful not to touch any printer components) after removing the paper restart the printer, then redo the printing process.
-Paper jam inside the machine
Open the rear cover, if you seen the paper remove it, then close the back cover then restart the printer and redo the printing process, if your unable to get the paper from the rear cover, open the casette infront of the printer and slowly pull out the paper, return the casette and restart the machine..
If your still unable to get the paper,
remove the casette, stand the machine with the left side on the buttom (make sure its not the right side) pull out the paper while pulling the green cover toward you, return the casette, restart the machine and redo the printing.
If your having difficulties or still unable to remove the paper contact the canon support center in your area.
Here is a link where you can see visual step by step procedures.
I hope this will help you a lot.
Thank you for choosing fixya.
Mar 03, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Display says " open front cover"
where the rollers are located is a small electric eye sensor that detects the paper, I would almost put money on it that there is dirt of some kind down in there, and it is blocking the sensor, so it says "jam" even if there isn't any paper in the printer at all. Give it a real good cleaning in that area and all should work as it is supposed to.
Dec 15, 2010 | OKI C5100 Laser Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Stylus CX9400 Photo Printer: paper jammed inside printer...
May 18, 2010 | Epson Stylus CX9400 Photo Printer
380 paper jam
Pull out the toner&drums and see if its under there
Oct 08, 2009 | OKI C3200n Led Printer
Kodak All-in-one Printer has Paper Jam problem
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Sep 15, 2009 | Kodak ESP 5 Printer
Xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Mar 06, 2008 | Xante CL30 HSE Laser Printer
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
Xante CL30 HSE Laser Printer Logo
563 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
