Question about Olivetti JP 192 InkJet Printer
Olivetti any_way wi fi printer
I have put the cd-rom in and now have the manual on my computer. However my laptop does not recognise the printer even plugged in with a
usb cable.
I understand this might be something to do with firewall blocking it. What do I do? please. My laptop is a Dell Inspiron 1525.
Thank you.
axonmaxon@aol.com
  • axonmaxon Jun 30, 2008
    it was my own solution.
I have acquired an Olivetti simple way priner/scanner/copier and my dell inspiron / 1501 will not accept it. I have not got a disc.
The computor told me to get in touch with the makers is this th right place.
vertutti@hotmail.co.uk
Posted on Aug 23, 2008
I fixed the problem by ringing the olivetti helpline. They told me I needed a different disc to download. One for vista. Thanks anyway.
Posted on Jun 24, 2008
Why is My HP printer not connecting to Wi-fi?
You sound as though you wish the printer to directly connect to the laptop via wi-fi. This is not usually the case in home networks. Most home networks use a wi-fi router to link all wi-fi components. This is because your laptop is not capable of handling the routing duties itself, nor is the printer (normally). The wi-fi router assigns the IP addresses that the devices use to communicate to the router and each other. That said, IF you ARE using a router, perhaps you are not entering the security code that the router needs to allow the device to attach to the network. If you are NOT using a router, then you still MIGHT be able to use the printer with the laptop if it has a "direct connect" capability. You would need to look at the printer documentation and instructions on how to set it up. Unfortunately, wi-fi isn't as simple as just turning it on an waiting for a connection to take place.
Aug 05, 2015 | HP Office Equipment & Supplies
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
Which softore are instal for wiffi
You have to install the software that came with your WiFi adapter (or Laptop). But, If you own Windows7, the computer detects it automatically and therefore you dont need software.
Jun 04, 2011 | Computers & Internet
I need help setting up my ANY_WAY WIFI PRINTER, using the wireless settings. I done it once before about a year ago and had to recover my laptop since and cant remember how I done it!
Hi.
You need drivers and an USB cable.
First install the printer as USB, then follow Activating Wi Fi components. Procedure is detailed from page 9/part 3 of manual below.
Here the manual for Olivetti AnyWay
If you have misplaced the printer disk, then you will need to download the drivers from Olivetti website: CUSTOMER CARE - Olivetti
Sep 13, 2010 | Office Equipment & Supplies
How do i do a wireless connection between computer and a kodac 5100 all in one printer
http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/5100AiOPrinterUG_EN-US.pdf
follow this manual ...
  1. Check the Wi-Fi Status Indicator on the front of the printer:
  2. Status: Do the following: Off
    1. Select Menu (or Home)>Network Settings and press OK.
    2. Select Turn Wi-Fi Radio On and press OK.
    3. Select Wi-Fi Setup Wizard and press OK.
    4. Select the SSID (name) for your router.
    5. If you have your network secured, you must also enter your password.
    Blinking
    2. Select Wi-Fi Setup Wizard and press OK.
    3. Select the SSID (name) for your router.
    4. If you have your network secured, you must also enter your password.
    5. NOTE: If the message Your printer is already configured for Wi-Fi network appears, your printer cannot find your router.
    6. If this occurs, check that the router is turned on and located within 100 ft (approximately 30 m) of the printer.
    On The WiFi Status Indicator could be on, but you could be connected to the wrong router if you used the manufacturer's default SSID and password when you set up your router. If this is the case:
  3. Select Menu (or Home) from the printer control panel on the front of your printer.
  4. Select Network Settings and press OK.
  5. Select View Network Configuration and press OK.
Place the KODAK All-in-One Printer Software CD into the CD-ROM drive on your computer.
Follow the on-screen instructions. Do one of the following depending on the version of KODAK All-in-One Home Center Software:
  • When the KODAK Printer Setup Utility screen appears, select how you want your printer to be connected:
    • USB cable
    • Wireless Wi-Fi® connection
    • Ethernet cable
Oct 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Having troble connecting to internet, an it has to do with the computer
try to turn off your wifi button then turn it on after 1min. or go to network connection and check your ip, it should be obtain the ip address automatically.
Sep 29, 2009 | Computers & Internet
Olvietti
The company that made the printer should have a web site, this is one I found that should help http://www.opendrivers.com/company/21438/olivetti-free-driver-download.html3
There are many others if you google it. Just go there, download the driver(program that makes the printer work with your computer) and you should have it. You can also take the file and save it to disk so you have a disk with the driver on it in case you get a new computer.
Nov 01, 2008 | Olivetti (AA6195) Internal 8x CD-ROM Drive
Olivetti Any_WAY Wireless with Wi Fi & Blue Tooth Problems with connecting Wi fi
What Wifi are you using?
Remember this only works with WiFi 802 B and G, if you are using A it won't work.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Thanks!
Dec 11, 2007 | Office Equipment & Supplies
Olivetti JP 192 InkJet Printer Logo
213 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Coss
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
