Question about Canon PowerShot A85 Digital Camera
Change batteries message pops up with new batteries
Hello, I've always used chargeable batteries, but lately, immediately after they've been charged, the 'change batteries' message pops up on my A85 Power Shot camera.  I tried using fresh Duracell batteries, and the message popped up after only a few days (camera use no higher than usual). Can you tell me  how long, generally, I should get out of my camera with fresh batteries (maybe my chargeable batteries are done?), or if this is indeed a 'trouble-shooting' problem that you can help solve. Thanks! Lianne
  • lianne d Jul 18, 2008
    This was helpful, as the problem did indeed turn out to be battery-related.  For whatever reason, however, I have noticed that the second set of fresh Duracell batteries I've been using have been lasting as long as they always have in the past (when I've had to use them vs. rechargeable), which is plenty more than a dozen shots (as per the Guru's comments above).  They will die soon, though, and at such time, I'll certainly be purchasing new rechargeables that are 2500 mah or better.  Thanks!
  • Canon Master
  • 4,738 Answers
Chargeable batteries usually last for a year or two. Alkaline batteries should only be expected to last for around a dozen shots (as such, NEVER rely on alkaline batteries). Recommend buying another set of NiMH rechargeables. Make sure you get 2500 mah or better power rating (look on the package).
Posted on Jun 29, 2008
I just got a sanyo model vpc-603 and it wont turn on even with new batteries
Are the batteries charged and inserted correctly ? It is always best to use the highest power re-chargeable batteries you can get, rather than the cheap ones from low-priced retail outlets.
Dec 26, 2016 | Sanyo VPC-603 Digital Camera
My battery comes dead really quick is there a way to boost it?
check the mhr on the batteries you use
they should be re-chargeable batteries as alkaline batteries do not have what it takes and run down very quickly
the re-chargeable battery should be around the 2000 mhr rating
Mar 30, 2015 | FUJIFILM Cameras
Battery light won't change colors, drops to 0% once unplugged
Let the battery completely discharge all they way and let it sit for a day or so. Some times when a battery is new most user do not let it fully charge and then completely drain this causes problems for long use batteries. Then give it a try. It also sounds like your plug your cord that connects to the battery may be faulty. Did you by a different cord with the battery? Or use the one from your old one? If you did. This is a "No No" always buy the cord that come for those battery since they are rated for the particular battery.
Feb 25, 2012 | Fujitsu LifeBook A1110 Notebook
I have put new battery in the phone. When I coonect the powder, I have display on the hadset screen also the charge symbol is flashing. I have charged for 24hrs but it is still flashing! As soon as I took...
Firstly always use rechargeable Alkaline batteries. If your phone has been working prior to your change of batteries then the problem lies with battery contacts in the phone even when you place the batteries correctly. They are not clean. Clean them with a abrasive cloth. Now fix the new batteries and see if they are being charged. If still the problem persists then get the contacts checked up for any contact not functioning.
Has anytime the old battery busted/leaked inside the phone????
Feb 14, 2011 | Lands Phones
How do I change battery in my lr3 key fob
You do not change the battery as it is re-chargeable. It is charged in the key fob unit while it is in the car's ignition and while you are driving the vehicle.
If you have a spare key that has low battery power then it needs to be used in the vehicle to charge the battery.
If you have been using the key fob and it has suddenly failed this is probably due to a faulty circuit board. You will need to replace the key fob with a new one from the dealer. It needs to be programmed for your car by the dealer.
Always have a spare key for this vehicle and keep the battery charged by using it occasionally.
Dec 17, 2010 | 2006 Land Rover LR3
It's been 4 days ago since my cellphone gets a problem bout sending message.,..every time i send a message the message "Message Sending Failed" immediately pop out
ok before contacting your provider try taking out the sim card and battery. while there out i want you to put the sim card in before the battery then after sim is in put battery let it sit for 2 minutes then turn on. (also before starting make sure battery is fully charged, if not charge it before doing anything. Or if you have a backup battery use that, make sure its fully charged also)
If this is a new service, and your just recently using it, make sure #1 you have the data package activated from your provider #2 make sure they dont have your account locked because of an unpaid or late bill. cell phone operators are alowed to lock services if bill is late or not paid on time. there grace period is only 30 days max
Mel
if this helped please spend the time to rate the service
Sep 27, 2010 | Computers & Internet
The chargeable batteries in my trusty philishave 5830 have been running down gradually. Lately, the shaver got quite hot when a plugged it in for a re-charge. Now, suddenly, it will not charge at all, so I...
It is impossible for me to say for sure without actually looking at it but the problem is, most likely, the battery. Changing it will probably fix the problem.
Take a look at the circuit boeard for corrosion or burnt spots. If you see neither of these, I would say that there is a 98% chance that only the battery needs changed
Aug 26, 2010 | Philips Philishave HQ5812 Electric Shaver
Z650 not working not turning on new batteries on screen does not lighr
Hi make sure you have charged up your new batteries, Always the new rechargeable batteries are to be charged to minimum of 8 hours of time to keep the memory of the chargeable batteries active. Hope this helps you.
May 24, 2010 | Kodak EasyShare One Digital Camera
Camera is 3 years old. Lately I take a picture
All the battery have a life time fixed working hours. Your battery is charged but he complete is working time. Thats why these msg will come. Dont warry use the battery when you see the power going down after a while of charging then change the battery and buy new 1. Good luck.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Jan 31, 2010 | Canon Powershot SD450 / IXUS 55 Digital...
Battery level always shows as low, even when new, charged batteries are placed in the unit.
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 20, 2009 | Fuji FinePix S2000hd Digital Camera
Canon PowerShot A85 Digital Camera Logo
163 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
