Question about Whirlpool Washing Machines
How do i remove rear panel of my ultimate care 2 washer? it is not spinning. what piece do i replace?
  • Toby Norton
    Toby Norton May 11, 2010
    Most all the ultimate care series do not have removeable rear panels. Can you get me a model number? (When you raise the lid look towards the rear where the lid and the top of the washer meet). Also, When you close the lid, do you hear a click? When you turn it on to try and spin it, do you hear any buzzing or ratteling noises? Get back to me on these points and I'll see what we can do to get you taken care of.
  • 246 Answers
Since this question hasn't been updated in a while, I'm going to presume my suggestions corrected your problem? If not, feel free to message me back so I can get your model number and walk through other ideas with you.
Posted on Jul 01, 2008
  • Toby Norton
    Toby Norton Aug 10, 2008
    Just adding a comment on this one to get it off my work que. Please dis-regard.
Washer motor humms and won't spin after filing up with water
remove the water pump from the motor but not from the hoses and start the washer. if it starts then you have a sock or something caught inside the pump holding the motor. remove the object or replace the pump if needed. if the motor wont start then unplug the washer,remove the motor and turn by hand. if it feels hard replace motor. if it moves then leave motor out and move the gear case where the motor connects by hand. if it wont move then 2 things may happen. 1)gear case lockup or a piece of clothing caught between the tubs.
if the washer agitates but wont spin with the humming sound then I say the later. a piece of clothing caught between the tubs.
Feb 10, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Will spin empty but with a load will not spin.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Nov 16, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a whirlpool ultimate care 2 top load washer no spin
Sounds as if the drive hub which the tub is attached to maybe free spinning. Not an expensive part but does require a special tool called a spanner wrench to remove and replace.
Jan 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II washer leaks
Sounds like the pump is leaking.
Access to inside washer:
This one you remove the whole outside case and not the back.
Remove two screws on each side of the back control panel, you may have to remove the plastic trim on each end of the panel. The control panel flips back so you can remove two brass clips, unplug the wireing in the back center. The whole outside case can be removed.
The pump is in front and held on by two clips.
Feb 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer fills fine but will not spin
the motor coupling is broken. It is a cheap enough part but can be alittle time consuming to replace. it is located directly behind the motor. it is 2 pieces of rubber and i piece of plastic in between the rubber pieces
Jan 02, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirl pool washer bangs when in spin cycle
if new did you remove shipping strap in back..the unit cant lean more than 2 degrees..make sure clothes are even in tub..try to wash clothes alike..
Dec 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Top has rattle in spin
there are 2 screws 1 at each side at the rear of the control panel. these screws are going through the end caps at the back. remove the screws and the control panel folds back. there are 2 brass clips holding the top and sides to the frame. remove the clips and the top and sides will just pull away from the frame.
Dec 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care 2 washer wont spin
Are you in the Delicate Cycle? Do you have spin speed control set for slow?If both answers are no,than what is the model & serial number??
Apr 28, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
