LOW VOLUME ON MY SL-B35 TURNTABLE
MY TURNTABLE WORKS FINE ON MY VINTAGE SHERWOOD RECEIVER, HOWEVER, WHEN I CONNECT TO MY NEW DIGITAL SURROUND SOUND RECEIVER, THE VOLUME IS SO LOW THAT IT SOUNDS LIKE ALL I'M GETTING IS THE SOUND I HEAR OF THE NEEDLE ON THE RECORD. AND YES; EVERYTHING ELSE WORKS FINE ON THE NEW RECEIVER AND THE TURNTABLE STILL WORKS FINE ON MY OLD AMP. IS MY TURNTABLE PERHAPS INCOMPATIBLE WITH A DIGITAL AMP? I'VE TYPED IN THE TURNTABLE INFORMATION, BUT I DON'T THINK THAT'S RELEVENT, AS FRIENDS HAVE TOLD ME OF THE SAME PROBLEM WITH OTHER BRANDS OF VINTAGE TURNTABLES. IS THERE ANYTHING I CAN DO TO CORRECT THIS?
TIM
  • zipster77 Nov 24, 2008
    I have the same problem, however, I bought a preamp, and hooked it up between the turntable and my digital receiver, and am still not getting any sound out of the receiver. All I can hear is the sound coming off the needle of the turnable.
    Any help would be greatly appreciated!!
  • 1,512 Answers
Hi Tim,
You probaably do not have a phono input on the digital surround amp you are using. Your sound is bad for 2 reasons
  1. Your Turn Table has low output level,about 100 times less than a CD player.
  2. You need RIAA equalisation to reduce the treble and boost the bass. This is for replaaying any modern vinyl or LP's
You can get an outboard preamp that matches the output of your T/T to suit the normal aux input on todays digital surround amp.
You can get one online from here. Or if you are keen build one from a circuit here
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards robotek
Posted on Jun 24, 2008
Sherwood RX-5502 receiver - get no sound.. checked polarity - OK... replaced speaker wire - OK... checked speakers on another device - OK.... tried phono and tuner and cd player - no sound with any........
After doing all this troubleshooting on your receiver, Check if master volume on the surround levels are too low. Adjust master and surround level.
There may aIso incorrect selection of the input source. Select the correct input source.
If after doing this the problem still continue, it means the sound ic in the receiver is damage. the sound ic brings out the sounds from the receiver. You will have to open the receiver to locate the sound ic in the receiver and use the multimeter to read capacitors and change the damage ones.
Thanks for using Fixya.
Jul 11, 2010 | Sherwood RX-5502 Receiver
Distorted sound on Technics SL-1200/1210
You could be getting acoustic feedback from the speakers to the TT's. Lower the volume or somehow isolate them from room sounds and vibrations.
Jul 05, 2010 | Technics SL-1200 Turntable
Turntable output level too low and plain compared to CD, etc.
Get an external pre-amp. They range in price from 25-100 and more, depending on the capabilities. All over Ebay, and electronics sites. That will fix your problem. Hope this helps
Jul 06, 2009 | Technics SL-BD20D Turntable
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
Low volume and unbalanced deck
Turntables require amplification, they have very low output on their own. If your Sherwood has an Aux input try using that, older receivers often had a built-in pre-amp on the aux jack. You can obtain a stand alone pre-amp for less than $50, I use one from mcm, #40-630.
Dec 29, 2008 | Technics SL-BD22 Turntable
Technics SD-L3 TURNTABLE
Does your receiver have a dedicated phono input? If not you'll need to use a preamp between the turntable and receiver. Your other turntable may have a preamp built in and the Technics not.
If this does not help, please post the brand and model of both your receiver and your other turntable.
Oct 14, 2008 | Technics SL-1210 Turntable
PS-T3 connection to Sherwood 4105 Receiver
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
Oct 14, 2008 | Kenwood KD-291RC Turntable
209 people viewed this question
 Grubhead
Grubhead
