Question about RCA D52W19 52" Rear Projection Television
Convergence problems when you go into menu do you see covergence in setup,if not then it is not your convergence boards,next to your fiyback transfomer this is the power supply board there is 3 small fuses the one in the middle opens FL231 they look like small brown square caps 0.4 This is what I found where can I get the fuse and how do I change it? I would appriciate any info you can give. Found the fuses but not the convergence chips.
    President:
  • 1,284 Answers
You also need to unsolder the flyback transformer to trmove the lead free solder and then re-solder it with 60/40 solder to make sure this doesn't happen again.
Posted on Jun 26, 2008
We can not locate the convergence on our RCA HDTV remote?
what is the model 0f television. customer covergence options are in the setup menu. how does the piture look? under customer option setu menu do you have the covergence option? tell me and i will see if i can help
Oct 09, 2010 | RCA Televison & Video
Help with RCA projection TV P46812BL (chasis ptk195AA)
You have probably blown one of the convergence ICs. Effectively the easiest thing to do is replacing the whole convergence board, so that no soldering is involved.
Here you can buy a replacement convergence board, just select your model.
Let me know if you need further help.
Sep 13, 2008 | RCA P52930BL 52" Rear Projection...
Picture bowed
Recheck ur connections and the covergence board the same make or return and exchange for another convergence board.Sound like u still have convergence problems.
Jun 11, 2010 | Samsung HCN4226W 42" Rear Projection...
Ghost image arcs over picture
This tv have a convergence problems,it dead.The covergence board the 2 STK convergence ICS and some or all it resistors are dead.All these parts must be replaced to solved covergence problems.The shop will cost U $300-350 for parts and labors.
May 26, 2010 | Philips Magnavox 51MP392H Rear Projection...
I need to know what convergence board I need and part number. TV is RCA Model HD52W59YX36. Symptom is see 3 d like shadows. When I go to do the covergence adjustment from the setup menu....nothing appears...
You dont need a convergence board. The convergence option missing from the setup menu is a easy cheap repair. www.tvrepairworld.com has the kit called ITC222 & 222A convergence option missing repair kit. It also has the CD with instructions along with the three components that repair that problem.
Mar 27, 2010 | RCA HD52W59 HDTV Projection Television
Sony tv covergence
I think that if you go to the menu and under setup there will be a convergence option, or at least with my sony 48" thats what it is.
Nov 16, 2008 | Sony KP-51HW40 51" Rear Projection...
Double print and curve screen
this is an indication of convergence problem. from your description the curved screen indicates complete loss of covergence. First question is in setup menu do you have the convergence option? if no then it will be the fl231 fuse problem. common to these set and if you can solder. its not a difficult repair. if you do have the option. then it can be any or all of three cuircit boards. let me know and i will do my best to see if i can help you fix it
Aug 31, 2008 | RCA HD52W58 52" TV
Convergence problem
when you go into menu do you see covergence in setup,if not then it is not your convergence boards,next to your fiyback transfomer this is the power supply board there is 3 small fuses the one in the middle opens FL231 they look like small brown square caps 0.4 amps.
Jun 05, 2008 | RCA D52W19 52" Rear Projection Television
Covergence problem
your set has indications of several problems. red green and blue. indcate convegence issue. the fact that the picture is concave is a indication of totall loss of covergence power supply. the convegence menu missing idicate loss of some voltages from what know as the flyback.AND SHUTDOWN. indicate further problems. generally when convergence fails ..not always the set wont shut down. it could be a simple issue but further trobleshooting would have to occur to narrow it down.
Feb 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Convergence board replace, still cannot manually adjust covergence
Do you have everything pluged in?
did you get a new board or repaired board. I think it's defective if everything checks out
Apr 14, 2007 | Samsung HCN529W 52" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
