Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6310xi sluggish in copying, then spits out blank paper, error messages says...
Out of the blue, my HP 6319 all-in-one has a problem with copying. The machine is very sluggish in copying an image, then spits out a blank sheet of paper. My error message says to replace the left cartridge (the color cartridge) which is brand new. After inserting the new cartridge, I was able to copy documents for several times successfully when suddenly, I wasn't. Can anyone shed some light on this for me? It doesn't matter whether I feed the machine from the top or use the glass, it's not copying either way. Is this something I can solve on my own, or do I need professional help?
Susi
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
jmassengill
  • 345 Answers
SOURCE: The printer doesn't recognize the new original HP color cartridge
There is a small spring that holds the ink cartridge in the ink holder. You will see it stick out from the right hand side of the ink holder where the ink cartridge slides in. If that spring isn't being held to the ink holder by two plastic tabs, (I.E. the plastic tabs are broken) the printer will never recognize the cartridge. If the printer is still under warranty I would contact HP or an authorized repair center for HP. Both the black and color ink holder has this spring. I know of no way to repair this kind of breakage.
Posted on Jan 08, 2009
leroyal
  • 2120 Answers
SOURCE: HP 1610 alignment failed error message
replace black also
Posted on Jan 25, 2009
  • 4 Answers
SOURCE: HP Photosmart 2610 printer - had been using the
Have you tried replacing the cartridges all together? That worked for me. I use HP 96 and 97 cartridges.
Posted on Jun 16, 2009
Will not copy
This means one of the cartridges is defective, they cant align if they cant print. What i did to fix this problem is insert 2 working cartridges and get it to align properly, even if they are low on ink, then lift the cover and the cartridges will move to the center. When this happens pull the power cable out, then insert the full non functioning cartridge. Plug the power cable back in. I tried this with a color cartridge, the color cartridge was non functioning but i was able to print in black. Basically you align the cartridges and then swap them so the printer thinks they are still aligned. The color still doesnt work and it is probably a defective color cartridge.
Apr 20, 2013 | HP Officejet 7210 All-In-One InkJet...
PSC 221 won't print with it's drivers when I'm
HP has a support document here for XP and the blank pages issue: (copy and paste the link into your browser)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01892627&cc=us&lc=en&dlc=en&product=79499
Hope this helps!
Dec 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP 8500 all in one printer: error 0x61011bef
0x61011bef is a general error that the chipset in the printer gives instead of a "carriage jam " error message.
Double check inside the printer as well to ensure that there is no bits and peices stuck insde the printer where the carriage assembly ( where the printheads sit) check to make sure that moves freely.
as well as clean the rollers on the back of the printer... silly yes but it has been know to cause an error if there is built up paper dust on them
Nov 09, 2009 | HP Officejet 6500 Wireless All-in-One...
I have an HP officejet 6310xi that is not feeding the paper through. I can't print or copy anything. I have gone to the HP.com site to try their troubleshooting methods, but nothing is working. I have a...
Not sure if you're saying it's jamming or it's not picking up paper.
If the paper is jamming, this video should help.
If the paper won't pick up, this video should help.
Sep 25, 2009 | HP Officejet 6310 All-In-One InkJet...
Prints hieroglyphic rubbish in the middle of printing mult copies
MY HP PSC 1410 WILL NO LONGER SCALE PHOTOCOPIES TO LARGER SIZE THAN THE ORIGINAL.
Jul 13, 2009 | HP Photosmart C4480 All-In-One InkJet...
Will not "Print" copies.
It may be that you are putting the page face down in the paper feeder when it needs to be face up or the other way around.
Jan 18, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Fax machine jams or stops loading document for a copy or sending fax
try to open your fax machine ang check paper feed gear maybe 1teeth of gear is broken..or maybe your machine incountered feeding timing error.
Jan 30, 2007 | Panasonic KX-FL511 Plain Paper Laser Fax
HP OfficeJet 6110 All-In-One InkJet Printer Logo
29 people viewed this question
Ben Johnson
