Question about Kenmore 22313 Bagged Canister Vacuum
Model 116 hose clog?
My old cannister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexable tubing attached to the canister but cannot get it apart. Advice?
RJ
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
Owners manual for kenmore power-mate # 116
Greetings from GoVacuum,
I wasn't able to find the manual for the Kenmore model, however I did find the instruction manual for the corresponding Panasonic canister vacuum cleaner. Your particular Kenmore model is actually made by Panasonic for Sears, and then Sears puts the Kenmore name on the vacuum cleaner. They are identical internally, and have the same parts and components, besides the filter that is behind the bag. Sears makes Panasonic put a specially designed filter in the Kenmore's so that the customer has to go back and purchase that filter from Sears.
To download the instruction manual, please visit the link below;
Owners Manual For Sears Kenmore Power-Mate Model 116.3489890C
You can also find a parts schematic of the power head below if you need to purchase parts;
Parts Schematic For Sears Kenmore Power-Mate Model 116.6489890C
I hope that this information helps you. Please let us know if we can provide you any further service, or if you have any further questions we can answer. You may email me at chris (dot) jones (at) govacuum.com.
If this helped you, please click the Helpful button below.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Kenmore Vacuums
I need the owners manual for kenmore cannister 24212
If you type in the model number on your searchbar, the website will be listed "after" all the sponored sites. Use the site that has YOUR manufacturers name in the url. Under the "support" section choose manuals and especially the term pdf. Thank you, Dana
Feb 13, 2010 | Kenmore 24212 Whispertone Bagged Canister...
Kenmore 3.9 with power-mate Model 116 2839581. Can't locate screws to allow cover removal for access to motor
You have to take off the top of the power nozzel that has the light lense. There are two pressure locks,one on each side. Use a screw driver to release. You will see the screws.Take the two screws out and on some models, there are two pressure locks on the back of the nozzel. Again use the screw driver to release. The top should come right off.Hope this helps.
Oct 18, 2009 | Kenmore 22313 Bagged Canister Vacuum
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Can you tell me if Powermate Power Brush attachments are all the same for all the Sears Powermate Cannister vacuums.  That is, would one power brush attachment on a Model 116.56512690 fit one that is Model...
i think your confusing model #s ,as the 116. 22512202 is the canister model number and the model number of the powerbrush attch would be 116.52512202,but to answer your ? no it depends on which wand your useing that determans which one you can use
there 3 types of wands 1 telescoping which comes only on progressive models 2 a 2 piece with wire connected and a 2 piece
wire not connected,hope this helps,les
Jan 03, 2009 | Kenmore 22812 Bagged Canister Vacuum
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Kenmore 22313 Bagged Canister Vacuum Logo
673 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
