RCA HD52W56 52" Rear Projection HDTV Logo
Posted on Jun 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color is off and picture curves inward
Same as everyone else that has posted. There are colored shadows of original images and the picture curves inward from the top and bottom. I am wanting to know what one can expect as far as the cost to have the convergence rebuilt.
  • bleafr Aug 27, 2008
    I cannot get my auto convergence back which i have used before and i have a 3d image and blur. I had already changed the red bulb 7 months ago which cost $200 i can't figure it out
  • Anonymous Sep 28, 2008
    i have the same problem as well the picture comes inward from top to bottom and the colors are not convergeing togerther properly
Anonymous
Level 3:
Genius:
  • Master 1,030 Answers
  • Posted on Sep 29, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1030
Questions
Helped
227597
Points
2244
You do not have the convergence option? check out my article on the fl231 problems under tips and tricks. if this is the case it could be as simple as 5 dollars and 30 minutes if you can solder a component
Anonymous
Level 2:
Champion:
  • Expert 317 Answers
  • Posted on Jun 24, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
317
Questions
0
Helped
62505
Points
462
Depends on your geographical area...300-450
How do i take out shadows in a photo
In Photoshop, choose the Select menu and click on Color Range... Then click on the offending shadow. You will see that area highlighted in the small window. By holding down the shift key and continuing to click on offending shadows, you can add to your selection. Also adjust the Fuzziness setting to suit your preference. Click on OK, and you will see your shadows selected in your image. Now go to the Image menu and select Adjustments/Levels... or Adjustments/Curves... Adjust the sliders, or the shape of the curve to suit your preference. Save your file with a new name in case you need to readjust.
Oct 07, 2014 • Cameras
1helpful
I have a Phillips 60" rear projection TV. recently
Tv have a problems known as a convergence problems,it is dead.The tv convergence board it is dead,that why ur tv picture are R,G,B colors lines mis alignments,have colors shadows picture or 3D picture lood alike?The tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
2helpful
PICTURE IS BOWING INWARD AND THE COLOR . LIKE PERSON FACE IT WILL HAVE A SHADOW OF RED, BLUE, GREEN, YELLOW
Tv have a problems known as a convergence problems,it dead.Colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are dead,must be replaced on the tv convergence board to repair the convergence problems.The shop,will cost u $300,350 for parts and labors.
2answers
Blurry picture
Sounds like convergence failure. (Colored shadows of images.)
2helpful
Color picture has outline or shadow of everything
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
5helpful
Multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
Red, Green, Blue curve upwards and cast shadows
that sounds like a typical Convergence IC problem..
http://i.ehow.com/images/GlobalPhoto/Articles/4575598/ConvergenceICs_Full.jpg
this is a picture of what typical convergence ics look like
2answers
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
convergence bad have it rebuilt
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
