Question about Refrigerators
I have a Dometic rm2807 rv refrig. freezer works ok but no cooling in main frig.(Gas or Electric)
  • Anonymous Mar 31, 2014
    top freezer is working but refrigerator will not cool in my rv
Check out this site
Posted on Jul 28, 2008
Dometic refrig not cooling but found yellow oil at service panel
if you find an oily substance its most likely freon. this looks pretty new so i would say you have a bad soldered joint on a copper to steel line. theses usually ar fot the high side. where the condensor coil or loop runs either to underref or up in the ref walls
Aug 01, 2010 | Dometic RM2652 Refrigerator
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
I have a Domestic 2804 frig in my RV, The freezer works great but the frig part will not cool at all, can you help
All cooling takes place in the freezer. The refrig/fresh food side is a parasite, depending on cold air circulation from the freezer side. The fan in the freezer provides that circulation, and usually the freezer control setting determines how much air is moved into the refrig side.
If the fan is up to speed and the both controls are set in a middle position, the refrig side should be fine. if the problem continues, replace evaporator fan motor or clear the blockage preventing circulation (usually frost build-up from a defective defrost system part or blocked defrost drain).
Jun 13, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Not cooling at all
Youneed a new sealed system, you have lost gas. ( Smells of amonia)_
May 27, 2009 | Dometic RM2193 Compact Refrigerator With...
Rm2807 rv refrigerator gas works but the a/c is not working
Check the 110 volt wire for flaws. Take a volt meter and check the recep that the fridge plugs into for power, should be 110 volts or so. +/- 10%. If you have power at the recep problem is in the fridge chord or circuit board fuse or circuit board. Also check the 110 volt breaker in the coach at the service panel.
Mar 29, 2009 | Dometic RM2852 Refrigerator
My 1995 Dometic 2611 runs OK all day but not at night
Yes more than likely the cooling unit is going bad. If your boiler tube is hot the cooling unit is no good. Your frig is 13 years old, it has reached its life span and beyond. A cooling unit or a new frig can be purchased from Just send them an e-mail.
Feb 28, 2009 | Dometic RGE400 Top Freezer Refrigerator
Norcold rv refrigerator freezer
Make sure the thermister is attached firmly to the fins in the back. The boards on a Norcold can be reset a service center familiar with this process is your best bet. It takes disconecting the board and then shorting it out best to leave it to some one who is familiar.
Aug 16, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
586 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
