Question about Panasonic PT-47WX53 47" Rear Projection HDTV
I need advice or help ect...
My Panasonic HDTV 1080i Color Projection System.
Has a double effect with one of the colors being pink.
Can you please help?-Marie
below is the model number.
  • babygirl 4 Jun 27, 2008
    Agent Dort.
    Dear Agent Dort.
    I tried setting the convergence if I'm not doing the wrong thing is it the 2 green lines that are suppose to meet in the center?. Well I don't have a remote so I pressed the keys on my TV. Because it said to press the Vol and Channel keys on the cabinet. And the lines would not move. I do really appreciate your help is there something I'm not doing right or can I try something Else? -Marie
    Novelist:
    Champion:
  • 216 Answers
Greetings babygirl4,
Most likely you need to perform convergence on your unit. It can be found in the setup menu of your television.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Posted on Jun 23, 2008
Panasonic hdtv 1080i picture bright
It could be your main board going bad.
Jun 01, 2013 | Televison & Video
Pink and green color out of focus people have one green hand extended with another pink hand double exposed features. Tried to adjust the color convergence and it won't work and it is all out of line and...
The mirror that projects the image on the screen from the lights below is most likely out of alignment, this is a very delicate adjustment to make. If your not familure with doing this, it will need to go to a shop. I hope this helps, if you have any other questions please contact me. Good luck.
Sep 23, 2009 | Toshiba 43H71 43" Rear Projection...
Samsung HDTV 1080i pictures doubled and theres rainbow colors!!!!
The convergence is dead.U know how to solder?Buy the kit with ur tv name and model.
Replace the parts in that kit.Should be back to normal itself.Or have to go to the menu see the convergence make miner adjustment.
Tries this website.TV Repair World.com have kits and instructions for many DLP tv's with this prob.
Sep 03, 2009 | Televison & Video
Panasonic Projection HDTV PT47WX49E. Can water
yes it can any liquid spills or bacteria can rot the system
Jun 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic hdtv projection colors will not line up
If only minor convergence issues, the setup menu has user controls for 9-point convergence. If it's major misalignment in just one color, you may have a blown convergence amplifier chip. Big bucks repair, unfortunately. Chipsare about 30-40 dollars apiece but labor will kill you if they'll even fix it on-site. Most try to order $700+ board which is no longer available. Teh they send yours out for -10 weeks at similar prices.
Jun 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
I have a panasonic HDTV 1080i. seeing double images
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Feb 17, 2009 | Panasonic PT-47WX53 47" Rear Projection...
I can't find my owner's manual for my Kenmark Flat Screen LCD TV Model No. 15KN10E5. Do you know where I can get one? I lost my manual and the screen has a double effect with the double having a pink...
this lcd is a few years old now and we have supported kenmark for the last 3 years and we do not have a user manual for this model.
i have never come accross the fault you descibe but it may be the lvds lead.
this should be looked at by a service engineer
Jun 18, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Need help with color on panasonic hdtv
Convergence circuit repair needed.....Requires chassis pull,
IC replacement and check / replace current limiting resistors.
T.
Apr 16, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Bill
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
90 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
