Question about Foxconn eBOT Barebone
Psu what is the power out put /+
  • kenloder Jan 12, 2009
    I have 15 of these computers.
    2 of my powersupplies have failed.
    Would rather purchase new/replaced item vs. modify notebook powersupply.
    Problem Solver:
  • 10 Answers
200 watt max. 19v DC power brick with a 4 pin plug, with two positive and two ground pins. The PSU is unique to the E-bot. I have not been able to find an exact match anywhere. Foxconn no longer sells the PSUs and will not help with tech support in any way. The PSU was originally produced by Fortron Source Power (FSP). When mine went bad, I had to buy a similar looking unit (but with only a 150 watt max rating), then I had to rewire the output cord, because the 4 pin plug had the positives and negatives switched around.
If you need a new power brick for the Ebot, I seriously hope you have the old original unit still. If you do, you can then simply buy any 19V laptop power brick that has acceptable power output (at least 120 watt) and then replace the power output cord with the original one from the Ebot's power supply (some soldering required). It's really the only way to replace the unit.
Posted on Jun 29, 2008
Put in fuel pump and have no power has power at fuse box
When are you checking for power? When you turn the key on, the main relay energizes the fuel pump for 2 seconds only, then shuts off the pump until you start cranking.
Nov 24, 2014 | 1997 Acura TL Series
Doesnt put out power
if it stopped putting out power when in use check the circuit breakers then ope the rear cover and look for overheated wiring if it just doesn't put out power after sitting remove the small cap on the end cap and with a 9 volt battery strike battery voltage against the two terminals a couple fast times then see if it puts out power
Sep 21, 2012 | Coleman Electrical Supplies
How to set microwave 50%
You have to put the cook time in first and then you press the power level button (just below the number 7 on the keypad) and put the power level in. The choices are 1 through 10. Fifty percent is probably power level 5. Once you have put in the power level, just push the Start button and it will start cooking.
May 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Motherboard wire hook up I pulled the wires : Power LED, Power SW, H.D.D. LED off the motherboard, don't know the pattern to put them back on.
its simple, start from left power led next to power led is power switch, just below power switch put hdd and next to hdd put reset . thats it done.. all boards have the same module.....
Nov 24, 2009 | Computers & Internet
The fans
there is only one socket for smps its 6 pin near processor (depends on motherboard architecture)
just put ........
Mar 28, 2009 | Dynapower (ADW-50063) (ADW50063) 500-Watt...
Push the on button and nothing happens
I believe you are using a new power supply now.
Before you start, first check if your Power button is OK.
To do this, first unplug the power cord from your PC.
Remove POWER-Button connector (with black/white or blue/white wires) from you Motherboard
Remove RESET-Button connector (with black/white or blue/white wires) and put it on the place of POWER-Button. (polarity for these buttons is not important)
Plug the power cord back and press RESET.
Does it change things ?
If it starts, then your Power-Button is broken.
If not, remove the power cord and then put te POWER-Button and RESET-Button on their places on the Motherboard.
Now do the following:
(please remember the position and polarity of all cables/items you remove/unplug, Use Digital camera if necessary). Be patient, don't hurry!
- Unplug the power cord.
- Press power button few times (power cord is unplugged).
- Remove the Battery.
- Unplug the Monitor cable and remove VGA card.
- Remove RAM module(s).
- REMOVE any PCI cards(Modem. Lan, Audio etc.).
- Unplug any HDD/FDD/DVD cables from the Motherboard.
- Unplug Power from all your HDD/FDD/DVD devices.
- Put the batery back (be careful to the polarity)
- Put the Computer power cord
- Turn on your PC.
Is the Processor Cooler running ?
Are there Beeps from PC Speaker?
If not, then your Motherboard is broken !
If there are some beeps, then your Motherboard is OK, but some component(s) is broken.
Turn Off your PC by pressing the Power button for about 4 sec.
Unplug the power cord and press Power button few times.
Put your VGA back, and connect the monitor cable, too.
Put back ONLY ONE memory module (if there are more).
Connect the Power cord and press Power button.
Do you have a picture now ?
If you have a picture, put back all other memory modules and PCI cards, connect Data and Power cables to your HDD/FDD/DVD units, but ONE at TIME.
Do not connect and put everything back all at once!
After each change, see if there is a Pcture and (one) beep.
It needs some time but that's how you will detect which device/cable is maybe broken!
And remember:
Before you do any change, AALLWAYS do that with power cord unplugged and power button few times pressed !!!
If there are Beeps, try another memory module.
Again if there are still beeps, you have problem either with your RAM or VGA.
If there are infinite long beeps, than it is your RAM.
If there is one long and many (8) short beeps, then it is your VGA
Replace it!
Mar 23, 2009 | HP Computers & Internet
Putting out half the volts
My 13 hp 8000 watt is not putting out any power dose it need to be exsited and if so were do i do it at?
Jan 13, 2009 | Northstar Generator 13 Hp, 8000 Watt,...
Orion 2400 mono
My esp light is blinking yellowish and the amp isn't putting out. I have power to it, just not putting power to my subs. anyone know how to help?
Feb 25, 2008 | Orion XTR Pro 2400 Car Audio Amplifier
Foxconn eBOT Barebone Logo
200 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
